190XT Steering Problem
bttpe1961 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bttpe1961 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Steering Problem
    Posted: 3 hours 28 minutes ago at 8:14am
Our 190XT stopped steering.  So far what I see is that there is no fluid flowing out of either hose going to the steering cylinder.  My assumption is that the steering pump has failed.  Do you guys agree?  The lift on the back still works.  I'm reading that there are 3 separate pumps and one is dedicated to the steering and likely needs rebuilding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 49 minutes ago at 10:53am
If the steering pump isn't pumping any oil, the tractor will NOT MOVE and pull any kind of a load. Yes or No ??       Power Director clutch creeping doesn't count as moving.
