Replacing the cork on a WD45 crankshaft |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5177 |
Topic: Replacing the cork on a WD45 crankshaftPosted: 4 hours 27 minutes ago at 3:08pm |
I am sure I read on this forum about replacing the pilot bearing on a WD45 with a sealed bearing, removing the cork from the crankshaft and threading the end of the crankshaft and installing a threaded plug.
I have searched and I have had no luck finding anything. Does anyone have any experience doing this. What size plug should be used. Any tricks that I should know? Should the plug have (red) Loctite? |
