Break shoe relining advice
MisterDRH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MisterDRH Quote  Post ReplyReply Direct Link To This Post Topic: Break shoe relining advice
    Posted: 18 Feb 2026 at 6:26pm
I am in the process of replacing the breaks on my Allis 175 and would like some advice. Disassembly went well with only minor challenges and I am at the point of attaching the new break linings to the break shoes.  The new linings do not meet the profile (radius of curvature) of the steel break shoes.  The replacement linings as significantly flatter than required.  How does one reshape the linings without breaking them?  Thanks in advance,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 6:57pm
rivet one end, then C-clamp the other to pull down against the steel.
rickcorder1954 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickcorder1954 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 7:13pm
In case you are interested, I DO reline brakes for a living and most of the material these days is junk...been there, done that! Brittle as heck and wears out very quickly...ask around about that if you want...call me at...314-488-9224, if interested...Rick
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 7:48pm
Lots of options for brake relines almost everywhere. I think Kentucky Clutch just south of Louisville will do it and they also reline the hand clutch as last checked a few years ago.
I had my hand clutch relined at Brownstown Equipment (Indiana) in 2024.  I'm not sure he really WANTED to do it, but he did :).
1952 CA13092
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 8:15pm
+1 on Ricks work!
I had to finally steam the last set of bought linings I did to get them mounted
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 7:01am
Rick has done brake shoes and, back when he did them, clutches for me. If I am replacing brake shoes, Rick is the only one I would consider getting them from.
I know you are going to say that you already have the brake linings. Changing the brake shoes on most AC tractors is a real pain in a low place. Do yourself a favor and get quality shoes from Rick. If you put cheap Chinese brake linings in, you will quickly wish you didin't!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 6:08pm
Rick is the man you need! Tracy
