Allis 7000
Empirestate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7000
    Posted: 16 Feb 2026 at 5:56pm
hello all,
  New member here. Been a lurker for a while and have gleaned a lot of useful information. Now I have a problem I could use some help. 1978 Allis,7000. It does not have differential lock, but all of a sudden it acts like it does. Just driving tractor only it steers, but with a round bale on the 3 pt. You can't turn it, not even using the breaks. I suspect something is wrong in the final drive, but what? Thanks for any help
    Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 6:18pm
The differential is locked up. There is a dipstick directly behind the cab under the SMV sign. I'm guessing your PTO seals have been leaking oil and that compartment is very low on oil.  Wheels have to come off. Axles get pressed out of their tubes. Brakes/brake housings come off. Lift arm housing comes off next. Then, you are down to the differential with the ring gear. Cab might have to be lifted a little, but not removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 4:56am
thanks Dr.,
  Are we talking major damage or parts not sliding as they should? I did pull the dipstick, it was low but
Still showed oil on the stick. Thanks again, Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 5:05am
dr. Allis,
  I should have asked am I going to do more damage if I were to keep using it? I still have to feed cows
Until the weather improves, also don' t have heated shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 6:28am
More damage?? Maybe and maybe not really. The affected parts are already junk. If you must continue to use it, overfill it 2 or 3 gallons from the top mark on the stick. Maybe even overfill with diesel fuel to act like penetrating oil inside the differential. It will not hurt doing this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 6:32am
thanks dr.
  Won't use more than I have to . What am I looking at for ruined parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 7:38am
Four seized pinion gears inside the differential case and a ruined cross at a minimum.  I only remember having to repair one over the years and it had 6K+ hrs on it and had done a fair amount of plowing in its iifetime.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 7:43am
Welcome to the forum. Goodluck.
Where abouts are you located
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 8:21am
This is the differential carrier from  an 8030 a few years back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 8:23am
That's pretty cool, Lynn. For sure when he placed it in "park" on a hill it rolled another couple of feet !!!
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 8:26am
Yikes! Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 3:30pm
thanks again DR., i'll post back in several weeks when I get it apart. When weather allows. I'll try to use a different tractor if it will pick them. Mike , I'm in the southern finger lakes area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 5:43pm
Dr.,
  Been looking at the service manual and it talks about splitting tractor. Where does the differential assembly come out?  Thru  the rear 3 pt. Lift housing opening or thru the front which would mean a split.
Thanks, Bob.  Just trying to get a handle on what I have to do and plan for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 6:34pm
Not sure of your mechanic skills- but maybe better off getting the complete rear off a parts tractor,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 9:06pm
No split required for taking the differential assembly out. Do as the Dr. says and roll it out the back, lift housing area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 11:04pm
Oh ok other side of state. We’re next to Hudson River
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 3:50am
thanks for the conformation Lynn.  Not too far Mike.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 7:27am
So how does that happen? Not using diff lock when needed and spinning the crap out of one wheel? To low oil too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 10:36am
steve, doesn't have differential lock, not spinning the crap out of it, just feeding hay. Slightly low on oil, but still above the low mark on the stick.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 11:08am
I assume you have the same issue while going in reverse?
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 12:32pm
acdiiesel, yes it doesn't matter which direction. Just gotta face the music and tear into it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 3:58pm
Differentials love to be flooded with oil. Overfull is always better than low on oil. in-furrow moldboard plowing used to be the worst thing for a differential, especially if the land wheel didn't have enough weight/traction. I've fixed a couple of 7030-40's over the years and it's always been due to LOW oil levels. You can have one of those tractors 5 to 8 gallons low on oil and all the hydraulics and steering work just fine. Too many neglected or foggy sight glasses. I always fill to the top glass plus a couple of gallons if it's mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 5:29pm
I hear ya  Dr. You can bet i'll be on top of it after this. Wasn't even being work hard, put 3 bales of hay
out every other day, other wise just sitting there. No noise or anything, just one day it started doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 6:26pm
How many hrs are on the tractor?? You haven't owned it all its life have you ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Empirestate Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2026 at 6:57pm
A little over 5000 if it's correct.I've only had it about 5 years, but it does what I need.
