D14 manifold bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D14 manifold bolts
    Posted: 16 Feb 2026 at 2:59pm
I’m replacing my manifold on my D14. My IT manual doesn’t give the torque specs for the manifold nuts. Google says 20-25 foot pounds, wanna verify that’s correct? Have a new gasket but I need to pick up some brass nuts to replace the old ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 3:56pm
your in the right range... Here is the chart for STEEL NUTS.. if you doing brass or aluminum i would use the GRADE 2 column, not the grade 5..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 10:06pm
Thanks Steve. I will go with 20. Wish AC had made the ears a bit more robust.
Edited by AC720Man - 16 Feb 2026 at 10:09pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 6:03am
I would re-torque several times after heat cycles.
