Two-Ten pto |
BLee Mn
Joined: 12 Sep 2009 Location: Montevideo Mn Points: 685 |
Topic: Two-Ten ptoPosted: 06 Feb 2026 at 3:00pm |
my pto brake doesnt seem to work, is it a simple fix?
Cowboy UP
DrAllis
Posted: 07 Feb 2026 at 6:34am |
The PTO clutch and brake are hydraulically applied. So, I guess you somehow need to "tee" in two 500 psi gauges into the steel lines going to the clutch/brake area on the lift arm housing. Maybe using a jumper hose looped around in a circle to get connected ?? With the engine running the pressure "engaged" should match the pressure when "off" in the brake zone. If pressures are equal, I'd say you have internal issues and the lift arm housing would have to come off to repair. I've never seen one that has failed. Remember, the PTO lever has THREE positions. Fully up is ON. Fully down is BRAKE. In the middle is COAST. The coast position ain't the brake position.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8971 |
Posted: 07 Feb 2026 at 10:33am |
It will run in coast with nothing attatched. Easy enough to knock out of "on" with your right leg when bush hogging.
BLee Mn
Posted: 07 Feb 2026 at 2:58pm |
yes i have pto postion lever all the way down, still turns
Cowboy UP
HagerAC
Posted: 09 Feb 2026 at 9:09am |
I've heard the pto valve in the 210 and 220 are likely culprits is what I've been told by others, I need to investigate ours as well, as it seems to slip under load, even though we don't really use the PTO on it. Tried it on the grain vac years back and it slipped under when it got a good load on it. Asked a few about it and they said the valve likely needed to be looked at and cleaned up.
DrAllis
Posted: 09 Feb 2026 at 9:28am |
BUT, even to do that, one should pressure test the clutch and brake circuits BEFORE and AFTER you work on the valve. There may well be pressure test ports on the valve, but it's inside the console and I myself have never worked on one (yet).
