Will a D19 Gas engine fit in my 190
aldrichg9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aldrichg9 Quote  Post ReplyReply Direct Link To This Post Topic: Will a D19 Gas engine fit in my 190
    Posted: 18 Nov 2010 at 11:38am
Hello All,
I have been lurking this forum for a couple of months while searching for an engine for my ~64 190 Gas (2500).
Ever since I got this tractor for free with a stuck engine I have been trying to do things as cheap as possible (story of everything right?)  And spending over a thousand dollars on a rebuild is out of the question.
I was able to get the engine freed and running again but with severely pitted cylinders it is quite low on compression and probably ate the rings...
Blah Blah you know the story.
My question is this:
I found a D19 Gas engine with new pistons for $400.
I have read that the 190 main transmission is the same as the D19 transmission.
Does this mean that a D19 engine will bolt into my 190?
I know that the G2800 Gas is larger displacement than the D19 but I believe that my  G2500 is the same diplacement as the D19 Gas.
Any help is greatly appreciated.
Thanks,
Greg
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 1:13pm
I can be done people put 190 engines in D19's. you will probly need the 262 back plate and flywheel and clutch assembly and make something for front mount. from what I measured before the 262 is about 4 inches shorter than 301 if it has normal front pully. you must have a really early 190 to not have the 301 cube engine I still think it's the same block as the 301.
B212,716,two 314H's,WC,WD,D19,190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 1:17pm
Far as I knew, the 190 tractors all had 301 engines. Isn't the hydraulic pump mounted on the engine on a 190? There isn't a place for one on a 262.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 1:26pm
I thought the very first 190 gassers were smaller cube but 301 block. I can't remember.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 1:34pm
Thats right Brian,about the pump. You would have to do some thinkin on getting hydraulics to everything.
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 1:46pm
One Ninety gas tractors were G2500 265 CID.  All XTs' (gas and diesel) and One Ninety Diesels were 301 CID.  Non turbo were 2800 engines and turbo were 2900s'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aldrichg9 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 5:45pm
Originally posted by Bret (OH) Bret (OH) wrote:
One Ninety gas tractors were G2500 265 CID. All XTs' (gas and diesel) and One Ninety Diesels were 301 CID.  Non turbo were 2800 engines and turbo were 2900s'. '.
This is what I was getting at.
Thanks everyone for the excellent and fast replies.
The numbers I have on the engine correspond to a G2500 265
Is the 265 completely different from the 262?
I understand about the hydraulic pump... But as I quickly looked over the engine in a barn today I saw what looked like a coupling where the hyd pump would hook up on the dist. side of the engine.
Maybe what I am looking at is a combine engine or something else?
Sounds like I need to find out what I am looking at, its just hard because its buried between a WC and an A in a dark corner... You know the story...
So to make sure I'm reading correctly what everyone is saying. A 262 D19 engine does not have the hydraulic pump mounted on the engine?
Thanks again for all your input it is a big help!!!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 6:14pm
Hone the cylinders and slap some NEW rings in and see what happens... Could be your old rings are just stuck in the piston grooves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 6:18pm
The two engines have nothing in common except the orange paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aldrichg9 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 6:22pm
Have considered it for sure, but I think I also have head troubles as it boils out all the water after about 15 minutes of running time.  Could be water pump not moving water I guess??? But looks like head to me.
Also you ought to see the look of the piston after I beat them to death trying to free them.  I left oil soaking on top of the pistons for 3 weeks pryor to attempting this maneuver.  BTW the day I got this tractor I drained approx 2 gallons of crystal clear rainwater out of the oil pan that came in through the exhaust.
I hate to scrap this thing as the hydraulics work very well and transmission seems to  work well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aldrichg9 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 6:54pm
Now thats the input I need to hear.  I hope you're wrong, but I need to know.
Thanks Dr. Allis
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 9:08pm
  WE HAVE A 190   GASSER   WITH A GOOD ENGINE WAS TOLD
    1-574-342-4545
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 10:07pm
Don't try to prove Dr. Allis wrong - you can't!  In this case, he is right.
