Rod bearing wear
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Rod bearing wear
    Posted: 01 Feb 2026 at 1:15pm
So this is a picture of a rod bearing from the engine I had the antifreeze issue with.
All six bearings have the same mark in the same place. What caused it? It is deep and can easily be felt. The crank looks and feels fine.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 1:35pm
Antifreeze has/is glycol. Glycol is in the glucose (sugar) family. Antifreeze in the oil reduces the ability of oil to lubricate the crankshaft.
At a very minimum, you have to first eliminate the coolant in the oil. I would change the rod and main bearings. The crankshaft should be measured (miked) to see how out of round it is.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 2:58pm
Ouch!!
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 3:46pm
You said the engine had been sitting for four years, I wonder if just the fact that the crank was sitting in that one spot for that long, could have done that.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 3:47pm
That doesn't look like frictional wear but rather more like a chemical reaction dissolving the bearing material Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 5:09pm
The bearings looked like that when I parked it. I thought it looked like chemical etching but can't figure out why or how they could all be in the same place, the holes for the oil don't line up in the same place on the bearings. I couldn't find new bearings at the time so it has just been sitting but have recently found some so am looking to get it ready as a spare/backup. Not that it makes any difference but it is an international UR450 power unit. The date on both the rod and mains is 6 74 so it has been a while since it's last overhaul. Forgot to add there was no antifreeze in the oil when I checked it 4 years ago and there is none in it now so thankfully the block did not freeze.
Edited by Acguywill - 01 Feb 2026 at 5:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 5:30pm
If you're going to re-use them, switch them around, top shell to the bottom and bottom shell to the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 6:00pm
I had thought about that, but the bad spot is on the bottom shell as it is and the edge of the spot is very abrupt. I was worried that if I ran it the bearing material would continue to break down and destroy the crank. Parts for old International engines are getting scarce.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 6:44pm
OK. I assumed your "sweet spot" was on the upper shell like many engines are.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 11:03am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 2:15pm
Originally posted by Acdiesel Acdiesel wrote:
this may help point you in the correct direction.
Thank you for that excellent link!
The photo in the section about corrosion does look a bit like the bearing that the original poster has, but it also shows some similarity to the example with foreign particles on the back of the bearing.
It seems unlikely that there would be foreign particles on the back of all six bearings in the very same spot. Could someone have previously filed down the bearing caps, resulting in an out of round bore?
I would be measuring those bearing bores very carefully.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2026 at 7:48pm
Thanks for the link Acdiesel. Reading the descriptions of the various types of failures I am thinking it is surface fatigue. That seems to be the only thing that fits what I am seeing. That would explain why there are bits of stuff imbeded in the bearing surface. I originally thought they were contaminants of some sort but when I took a close up picture and really zoomed in they look like flakes of surface material. Not shiny metallic flakes but dull colored angular shaped flakes.
TerryfromswIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryfromswIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 3:40pm
That is a delamination of the alloy from the steel backing. Hard to believe it happened to all of them but there it is. They look like an aluminum alloy not a copper/bronze alloy with a plating overlay or a lead bearing alloy with a tin plate overlay.
