Gleaner A modifcation
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner A modifcation
    Posted: 18 Nov 2010 at 6:58am
Ok guys, trying to 'justify' buying a nice Gleaner with a  10' head. I can't use it on my 'farm' of 1 acre but though gee what if I took the head off and put a snowplow  blade there?
Anyone else try this whacky idea?
It'd have great visibilty !! And a nice warm cab unlike my D-14 !!
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 7:06am
Just leave the head on and maybe the straw spreader would 'throw the snow' to one side....
I have seen something done with an old combine but can't remember what is was now. ?a back hoe?  ?a grave digging rig?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 7:47am
Check out Farm Show Magazine. Thats where I see it it done
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 8:13am
Find an old Uniharvestor. Then you can simply remove the combine parts and still have the cab. Add a 3 point hitch up front and a PTO and you can switch from the blade to the snowblower when needed.
Edited by CTuckerNWIL - 18 Nov 2010 at 8:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 8:18am
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 5:24pm
Hi Jay, long time no "see" (for me anyway). Thanks for asking the question, and thanks to Charles for the links cause ...
Although it's not Orange, I recently bought an IH615 combine for scrap price as a source of project parts (I'd like to make a small skidder for instance). However maybe I can use it for other things while I decide what to do seeing as how it starts and drives just fine.
I think it'd look good with a plow on the front like this:
cheers, Andrew
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 7:22pm
Go for it. Its amazing what inventiveness can do.I wish I knew how to post pictures. I bought at an estate auction a self propelled snow blower made from: 1)a massey combine cab/frame/transmission 2) a jd 3130 diesel engine 3) a 1 ton chev 4 wd front end for the steering axle 4) all meshed together with self fabricated sheet metal and a whole lot of genius. It is totally hydrastatic. The builder made it so that it is a 3 range hydro-both forward and reverse. For some reason beyond me, the snow blower is hooked to another 4 speed/with reverse transmission (I have a couple of blower fan speeds that are toooo! fast-I have never used the reverse either). He hooked the chev 4 wd drive to a hydrastatic motor so it's fully hydro and can operate independent of the front drive (at the auction someone had moved a lever the wrong way and when they started it up the drive wheels went one way and the steering wheels went the other). I think alot of folk thought is was broken-it wasn't. The builder/owner was a fellow named Maurice Newton (related to Issac Newton?). Never knew him but daughter talked to me after sale. He was a self taught hydraulic genius. There are more gauges and things on this that he had there for a reason, and most of it is beyond me. His workmanship is impeccable. Can it ever blow snow-like 50 ' in the air and 75' horizontally. Apparently it was written up with pictures in Farm Show. It also came with a fork lift attachment (the home made blower is easily removed from it's quick hitch. I stupidly didn't bid on his fully hydraulic vertical and horizontal rotary hedge trimmer (3 arm fully articulating) that went for about $100. When daughter told me she was hoping it all stayed together I approached the winning bidder but the price had risen 10 fold to $1000. I didn't bite. Sorry for the long winded post-but guys like Maurice deserve the praise even if posthumously.
