D15 Series 1 Front Axle
DAC9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DAC9 Quote  Post ReplyReply Direct Link To This Post Topic: D15 Series 1 Front Axle
    Posted: 27 Jan 2026 at 10:54am
The previous owner of our D15 Series 1 had four nuts as spacers positioning the wide front axle pivot bracket closer to the front of the tractor (away from the housing). I searched the D15 AGCO parts book online and cannot find the pivot bracket I have so I'm not sure I have the correct bracket. If I do have the correct bracket, I'm not sure if there was a plate or factory spacer that got replaced by the previous owner with nuts. The biggest issue with this is the little amount of threads that go through the pivot bracket do not allow the castle nut to thread on enough to install a cotter pin. Any thoughts on if this is the correct bracket for this tractor and if I'm missing a part that the nut spacers replaced? Photos of the bracket on the tractor and off are below. Thank you!
Edited by DAC9 - 27 Jan 2026 at 11:01am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 4:10pm
That is the correct bracket.  Someone put in those nut spacers to make up for the large amount of wear where the bracket meets the wishbone.  Chances are very good that your front pivot pin is worn out too.  I am currently rebuilding the front axle on my series 2 diesel.  After 60+ years, most of these tractors need to be built up.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 8:56pm
My guess is the front is wore enough that it dropped out once. This patch job shoved it in further to the unwore part of the front hole.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 1:33pm
Took a couple pics of this on my Series 1 D 15
Maybe they'll help ? Favorite son should post them soon. Good luck
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 2:42pm
DAC9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DAC9 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 4:08pm
Thank you for the information and photos! This helps a lot! My next task is to inspect the front pivot pin   area for wear. Was wishful thinking I might just need a simple part at the bell housing. Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 4:35pm
Sure, glad to help.
This page was generated in 0.058 seconds.
