Narrow front D-17's & D-19's
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: Narrow front D-17's & D-19's
    Posted: 24 Jan 2026 at 9:03am
Does anybody have info on how many D-17 and D-19 narrow front tractors were built?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2026 at 3:48pm
Swinford's bible has a table with limited info, on some years...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 8:14am
Swinford's book doesn't have any numbers for the series 4 D-17 from 1964 to 67. Without those numbers, the total NF tractors of D-17 and D-19's is less than 9,000 units. I have always said, I believed that A-C sold more WF tractors percentage wise than any other competitor in row-crop models.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 12:27pm
We're some of the wide fronts converted to narrow fronts for mounted corn pickers and maybe cultivating or other jobs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 2:38pm
For a corn pickers, sure and not hard to do at all. Cultivating ?? I wouldn't change to NF for that. NF's don't do the mud as well if there would be a wet spot in the field.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 11:21am
Wide front with 20" rubber and 38's on the rear....
Only issue i had doing this is it puts the rear cultivators at a slightly upward angle...
This was on a snap coupler rear cultivator...
If you had factory 3 point i believe you could adjust 3rd point to adequatey compensate....
This page was generated in 0.279 seconds.
