HD6 Crawler - broken leaf spring under the engine
Andymac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andymac Quote  Post ReplyReply Direct Link To This Post Topic: HD6 Crawler - broken leaf spring under the engine
    Posted: 23 Jan 2026 at 5:24pm
Hi All,
I've broken 2 leaf springs on my HD6, does anyone know if there is an aftermarket spring that can be purchased? I'm in New Zealand.
Is it possible to slide out the 2 broken ones and replace them without taking the whole leaf pack off? Any tips or tricks on the best way to do this would be appreciated.
Thanks in advance....
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2026 at 4:57pm
If you haven't already done it, you might also post in the Construction Equipment section
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andymac Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2026 at 5:10pm
Thanks, I’ll do that
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 7:47am
I have no idea of what is available in New Zealand, however around here there are many shops that make truck springs. If you have something like that, you could take the broken pieces to them and they could make new ones that match the size and curvature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 3:07pm
I assume they are a stack of leaf springs. If so, there is a center bolt that draws the whole stack of individual springs tight together in the center. No way to repair in-chassis.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 7:55pm
Is this a dozer, loader, or just farm tractor. Loaders seemed to have more trouble than the others.  They just put a solid bar across later model loaders.
Neighbors bought a Cat D6 with broken spring, found an older model D6 to buy a spring from. It was a bit lighter, but being somewhat careful it never broke.
So if you know of any old parts machines even if not a HD 6 check them out. Might be close enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andymac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 4:52pm
Thanks for your answers, I found a local company that will make me a new one. To clarify its an HD6 dozer that I have
