190xt injection line seals
A&Sfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A&Sfarms Quote  Post ReplyReply Direct Link To This Post Topic: 190xt injection line seals
    Posted: 22 Jan 2026 at 9:45am
Did an overhaul on the engine including injection pump and injectors for my 190xt 2 winters ago. The kit came with white plastic washers for the banjo bolts on the injection pump and some have always leaked, but the leak is getting worse. Bolts were torqued to spec upon install and have been tightened up as far as I feel comfortable since trying to get them to seal. I went to the dealer and they had aluminum washers with a smaller plastic washer inside as replacements at a cool $20 per washer. Needing 12 of them bad boys was going to cost a pretty ridiculous amount. The parts guy pointed me to a Deere dealer with what looks like a black oxide washer for $0.13 a piece. That was cheap enough for me to go ahead and buy and see. It has been way too cold for me to get them installed yet. Do you guys have the answer on this? Are the 2 piece, $20 washers the answer for a good seal? I was expecting copper, but no one offered that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 10:36am
Black. Get them tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 10:48am
black Deere one are what you want. Everything clean of course. Book say 35 ft lb IIRC. It's a scary pull and some impossible to get a torque wrench on. I do by hand and get em tight as Doc says.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A&Sfarms Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 11:30am
Thanks guys. Good to hear I ended up with the right ones then. And the cheap ones for a change! Definitely didn't tell the Deere guy what I was working on.... just in case.
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 11:59am
Working on a 185 with pump issues.Would those Deere seals your talking about be part number T20055?
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 3:04pm
I had a pump off a few months ago. I came from pump shop with 12 of the black metal washers for the banjo bolts. just like they have for 50 years.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 5:37pm
Paul,yes, that John Deere number seems to be correct. Also yes, that type of sealing washer is the kind to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 5:42pm
Thanks for the reply Lynn!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 6:35pm
Sometimes you have to tighten them up,, loosen then retighten,,,
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 11:03am
I have never seen anything but single steel washers -12 of them. Some were silver colored and some black. They are soft enough to deform and seal. I would doubt any non-metallic seal to hold the pulses at 3000 PSI +
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 4:26pm
I always found that once the washers leaked, they were almost impossible to get sealed without installing new washers.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 6:25pm
the pump on a 856 farmall that i done last spring had a little grove machined in the fittings on all the fuel supply and return lines on the roosa pump , they were alittle tapered nylon seal that looks like the steel ones but they will not interchange cnh was 10$ each
