7060 hydraulic issues |
| Author | ||
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Topic: 7060 hydraulic issuesPosted: 22 Jan 2026 at 7:06am |
I have a 7060 power shift that has no brakes, pto, 3point, hydraulics, and the steering works, but isn’t right. I bought the tractor with a bad engine, and just split it and coupled a front end on it off a tractor with a bad transmission. I pulled the screen and cleaned it and it was terrible before I put oil back in. Started it and it had brakes and 3 point I know at first. Picked up canister filters after I lost hydraulics and the right filter was backwards. Put new ones in and still nothing. Pressure gauge on the pto valve reads 1000psi sometimes when I start it and 3 point raises, but after that goes to almost nothing and won’t do anything. Any ideas? Piston pump?
| Sponsored Links | ||
DrAllis
Posted: 22 Jan 2026 at 7:48am |
Not knowing your experience makes it kind of hard. AGCO hydraulic filters only (2) under the belly and installed the correct way. Left filter must have a screen in it to open the internal oil door. Remove top sight glass and oil level needs to be that full sitting level and engine off for 20 minutes. Power steering not good is lack of oil or a bad pump or a stuck priority spool. You don't describe exactly what the steering ain't doing right. Power steering all starts at the left hand filter and it must be n AGCO filter. Stand-by pressure 400-600 psi with hydraulics at rest. 2400-2500 psi when activated. Which screen was dirty ????????????????
DanielW
Posted: 22 Jan 2026 at 7:56am |
There are other folks on here who know these systems better than me. But having just done a pile of similar diagnosis & repair work on a 7045 (and having learned a lot from helpful folks on these forums), I can comment with some knowledge:
As you probably already know, the 'hydraulic pump' on these tractors is actually three pumps coupled axially together. Going from the rear of the tractor (where they're driven from) to the front, you have: i) A geroter pump that pulls from the trans sump and puts trans fluid through the cooler, power-director (if a PD trans), and other tranny paraphernalia. ii) Coupled in front of that is a gear pump with flow divider, which pulls fluid from the rear axle sump (through the LH suction filter) and puts fluid through the power steering, cooler, second (RH) fluid (and into the surge chamber), and lubricating/cooling oil for the brakes and PTO clutch (note: COOLING and LUBE oil for the brakes/PTO clutch. Not the pressure to run the brakes and PTO clutch themselves - just the cooling/lube). iii) Coupled in front of that is a variable-displacement, pressure-compensated (closed-centre) piston pump. This runs the remotes, three-point, PTO, brakes, and diff lock. That's a bit over-simplified, but it gives the Coles-Notes version of everything. Now for your problem: A proper set of pressure gauges and checks is probably in order (which it sounds like you've started already). But because you periodically had brakes, three-point, and steering, I'm going to guess (/hope) that your pumps are whole and working in some capacity. It sounds like oil starvation problems, which are not uncommon on that series. The first thing to check is that you have lots of fluid in the rear end and (most importantly) the correct length filter in the LH housing. This was a well-known/common problem with these hydraulic systems. When installed, the filter 'should' be long enough to push the trap-door (called the 'anti-drain valve' in the manual) open and allow the LH filter cavity to fill. It doesn't push it open much - maybe 3/16" or so. A common problem was that these filters aren't all made the same. You really want to get the AGCO ones. The problem: All companies that make this size of filter make the metal filter-body length the same. But many manufacturers use different gaskets at either end. Most use thinner gaskets, and some use thin gaskets that also fit into a little recess in the end of the filter-body. The AGCO filters have much thicker gaskets adhered to the end of the filter body, making them about 1/8" longer than many/most other brands. If you use one of the other brands, they often aren't long enough to open the trap door and let the filter cavity fill (or rather, they only open it a smidge: They allow a little fluid to come through, but not enough to keep up with the flow demand and it will quickly/periodically starve for oil). Thus: A shorter or non-AGCO filter can cause hydraulic starving problems, resulting in intermittent or no hydraulics. Coupled with this (I learned this from a local old Allis mechanic) is a problem that can happen to the filter housing components if it's used with the wrong filter: There's a lot of surface area around the trap door and filter end caps. If it's been run with a slightly short filter, it can create enough suction/vacuum on this surface area to bend the end caps in a little, which further compounds the problem as it effectively shortens things even more. When you disassemble the components in the LH filter housing, it's critical to make sure the removable end caps and the bar that pushes the trap door are straight/square. It's also abolutely critical that the screen be installed in the end of the LH filter, as its thickness/length is required to open the trap door sufficiently. On my 7045 when I couldn't get an AGCO filter for the life of me, I got by for a little bit by making a second disc-shaped gasket our of some cork gasket maker to put in front of the filter and extend it a little, to make sure the trap door was opened sufficiently. I wouldn't want to run for a long period like this (when doing this, you're only relying on spring pressure to hold the filter against the gasket and keep everything in-place. It might last forever like this, but if anything ever went awry I wouldn't want it sucking the cork gasket into the pump). But worked dandy for a short test. I like my Allis's, but this design (and relying on gravity pressure to keep the filter filled) is not my favourite design. Because you're relying on gravity to force fluid through the LH filter, it's also critical that you have enough fluid in there AND a clean filter. When the filters started to get old/plugged they would cause similar problems, and some folks compensated by just over-filling the rear-end. This created a little more gravity pressure to help force fluid through the LH filter. So: First step (in my opinion) would be to ensure the LH filter is clean, has the screen on the end, and is the correct length/AGCO filter. At the same time, make sure all components of the filter (end cap, trap door pusher bar) are not bent in any way, to ensure that it's opening the trap door sufficiently far. Also make sure it's well topped up with enough fluid. After that, I would be suspect of the compensator and priority valves for the piston pump. It's not uncommon for them (not only on Allis's, but on any similar hydraulic system) to get some gunkulence in them and be sticky/jammed. It's fairly simple to take them apart, clean them up, polish the spools, and re-assemble with new o-rings. Take a look at this note and picture from the Allis manual. Note my sketches in red, which show how the T-Bar and end-cap can get bent over time (especially if the trap door hasn't been opening far enough and it's created a lot of suction pressure). ![]() Edited by DanielW - 22 Jan 2026 at 8:00am |
7060
Posted: 22 Jan 2026 at 8:01am |
The screen is in the left filter and they are new agco filters. The right filter the spring and plate was to the outside before I changed it. Dual speed pto shaft was robbed out when I got it and rag shoved in the hole so been setting without oil in it but everything looked clean in there when I dropped bottom plate to put the pto back together. The suction screen for the transmission pump was the one that looked bad. Hydraulic filters didn’t look bad though. Obviously the right one wasn’t doing anything. Has new oil in transmission and rear end up to sight glass. Steering acts like it’s got air in the line but pump doesn’t sound like it’s cavitating.
Edited by 7060 - 22 Jan 2026 at 8:03am |
DanielW
Posted: 22 Jan 2026 at 8:02am |
I should add to my last post: While I didn't have this problem myself, I read a few cases online about folks whose filter housings/o-rings weren't quite sealing correctly, and allowing it to suck air and cause similar problems. Make sure your o-ring on the cap that bolts the filter assembly in is straight and square with a good o-ring on it.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8943 |
Posted: 22 Jan 2026 at 11:02am |
Double check your hose connectins/positions since you just did a swap. Some lines can get hooked up wrongand cause crazy issues.
DanielW
Posted: 22 Jan 2026 at 12:14pm |
Hmm. While some more pressure tests are really the 'proper' next steps, if it were mine I'd start by disassembling, cleaning, and polishing the flow divider. Common problem for them to get stuck, causing the symptoms you describe. And they're easy to disassemble and clean with everything's still on the tractor. Take a look at this thread, where it's discussed in detail: |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2479 |
Thanks(1)
Posted: 22 Jan 2026 at 8:17pm |
As others have said, the power steering is kind of separate from the other hydraulic functions. It uses a gear pump and all of the other hydraulics are maintained by the piston pump. Both of these pumps get their oil from a common sump and filter combination. As the steering goes, jack the front end up and disconnect the power steering hoses at the cylinder. You should be able to turn the front wheels by hand without much of any resistance. Obviously, there will initially be oil in the cylinder which will need to be pushed out. Have some pans or buckets available to catch the oil and prevent a mess. I've seen them binding in the spindles to the point that you would swear that a new pump was needed.
Edited by Lynn Marshall - 22 Jan 2026 at 8:18pm |
Mikez
Posted: 22 Jan 2026 at 9:21pm |
There also was a post that even agco filters gave trouble.
Thought that was an interesting post.
DrAllis
Posted: 22 Jan 2026 at 9:50pm |
Please bring that post up. I don't remember AGCO hydraulic filters being a problem on a 7060 ......
7060
Posted: 23 Jan 2026 at 7:33am |
I took the compensator out and seemed like it moved okay. I pulled it out with my finger. Cleaned it up and put it back in. Nothing still. Is there somewhere else I can test pressure to figure out what’s going on?
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8771 |
Posted: 23 Jan 2026 at 7:36am |
I'm not sure how to bring that post up, but I do remember tbran posting about it, maybe 6 months ago???? Darrel |
DrAllis
Posted: 23 Jan 2026 at 7:53am |
There are two compensator spools and springs. Either can cause issues if stuck or broken springs. If they are OK, I might think a broken swash plate spring inside the piston pump. But, if the power steering isn't up to par (cavitation or gear pump failure) it has an effect on the piston pump !! because it charges the piston pump. That's why I keep harping on the power steerings performance.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 716 |
Posted: 23 Jan 2026 at 7:57am |
Sounds like the couoling between the first two pumps and the piston pump is stripped
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
DanielW
Posted: 23 Jan 2026 at 8:45am |
Interesting. The last two filters I've bought from an Agco brand were for a Massey - bought about a month ago. They replaced ones I'd previously bought from the same Massey dealer for the same tractor. The old ones I bought from that dealer (I think 2 years ago) said "Agco" on them and had the Agco part number. The ones I just bought a month ago are labelled (if I remember right) "Agrifilter", and are slightly different outside geometry.
I wonder if at some point in the past year or two Agco has changed who they're sourcing filters from. I heard a while ago that the proper Agco filters for these hydraulic systems were made by Baldwin, and that Agco sourced/badged all their filters from Baldwin. Maybe Agco has now switched from using Baldwin filters to some other brand?
DanielW
Posted: 23 Jan 2026 at 8:50am |
I also think that next time I change the L.H. filter in my 7045, I'll tack on some 1/8" flat-bar onto the face of the t-bar that pushes the trap-door open. It seems like there's lots of room to push more open, and that way no matter what filter I use, I'll know that it's opening sufficiently far.
DrAllis
Posted: 23 Jan 2026 at 8:53am |
Just position a thick Oring between the screen and the filter itself. I've done that for 40+ years.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3616 |
Posted: 23 Jan 2026 at 9:07am |
ALSO - there are screens in BOTH belly filters. 70269921 and 70269922 . In the past few years we have been adding an oring or pull the cork off the old filter and add to the new to help open the 'trap door'. We have not had an issue with oem filters, just want a little fudge factor on a 50 year old unit..
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3650 |
Posted: 24 Jan 2026 at 3:08am |
7060
Posted: 04 Mar 2026 at 8:57pm |
Just getting back to this tractor. So started it today and as soon as I started it the 3 point raised part way and the gauge showed just under 2000psi. Couldn’t get it to do anything after the first 10 seconds. Drove it around and steering worked like it should. Took the compensator apart on the pump and tried shimming it some more with a M8 washer.. still nothing. It acts like the piston pump isn’t getting oil to it since after it sets it works for a few seconds then starves out of oil maybe? Where does it get its oil from?
DanielW
Posted: 05 Mar 2026 at 7:33am |
Take a look through these pictures below (sorry for the large size - working off my phone on break here and didn't have the time to re-size). Sounds an awful lot like inlet restriction to the either just the piston pump or gear pump - either with trap door or filter problems. Though a problematic priority/divider valve also sounds like a possible culprit.
You said in your earlier post that the steering was 'working, but isn't right'. Is the steering working correctly now? Or still problematic? More thorough tests are probably in order. But as a quick/dirty start of where to start looking: If the steering seems dandy but the three point and remotes seem awry, I'd be checking out the R.H. filter area again. If the steering also seems wonky, I'd be checking the priority valve spool to make sure it shifts freely, and also re-looking at the trap-door/LH filter. No matter what, I'd probably still be pulling out the priority spool and making sure it shifts smoothy & easily in its bore. And I'd take the extra shim you added out of the compensator unless you've checked/set relief pressure as well. The compensator affects only the outlet pressure of the piston pump - the pressure it de-strokes at. Which doesn't really sound like your problem. Again, I'm jumping to some conclusions here and this isn't guaranteed. But it sounds like when the piston pump is getting oil, it's working ok, and thus the compensator de-stroke pressure and relief settings were ok. Sounds more to me like the piston pump isn't getting sufficient oil. I wouldn't be adjusting/shimming compensator de-stroke pressure without ensuring I know what the difference between de-stroke and relief pressure is: This is something to keep in mind on any variable-displacement/closed-centre pump: You always need to have the relief pressure set a little higher than the compensator/de-stroke pressure (usually about 200-300 psi higher, depending on the system). Otherwise you'll just be blowing over the relief and creating lots of heat & excess pumping before it destrokes. Shimming the compensator to increase de-stroke pressure without also adjusting (or at least checking) the relief pressure is a big no-no. ![]() ![]() ![]() ![]() Edited by DanielW - 05 Mar 2026 at 7:41am |
DanielW
Posted: 05 Mar 2026 at 7:55am |
Further to my last reply: I never really answered your question of where the piston pump gets its oil from. This is a little over-simplified and I'm sure Dr. Allis will correct me, but the simple version is this:
The piston pump gets oil from the gear pump. The gear pump gets oil from the LH filter, sends it through the priority valve. Priority flow goes through the steering, then through the cooler, then to the RH filter. From the RH filter it goes to the piston pump. There's also the surge chamber in the rear axle. This is a little chamber with a wall between it and the rest of the rear-end sump. There's a gap in the wall a couple inches from the bottom of the rear axle sump. When running in normal operation, the flow from the gear pump goes to both the piston pump and the surge chamber (the piston pump takes what it needs, and everything else goes to the surge chamber). This is because when you're humming along normally the gear pump delivers far more flow than the piston pump needs. When the surge chamber gets full, it spills over the gap in the wall back into the rest of the rear axle sump. But the piston pump can, at times, require more flow than the gear pump delivers for occasional short intervals (when using a high demand load on the remotes, for instance). When the piston pump needs more oil than the gear pump delivers, it takes this oil from the surge chamber. Thinking about it some more, this surge chamber might be part of the culprit in your system. If the gear pump isn't getting or delivering enough flow to the piston pump and surge chamber (either from problems in the LH filter, or because the priority spool isn't shifting properly), then it may not be suppling the piston pump or surge chamber adequately. There may be enough fluid in the surge chamber for the piston pump during the first 10 seconds or so. But once it uses the oil in the surge chamber up, it starves for oil if the gear pump isn't delivering enough. When you shut down for a while, oil is able to ooze its way into the surge chamber - enough to supply sufficient oil to the piston pump for the next 10 seconds or so. How it's getting into the surge chamber could either be from splashing over the wall from the rest of the rear-end housing (if it's filled higher than the wall), or slow leak-through some other part of the system. Again, that's over-simplified and the Doc will likely tell you better advice than I can. But if it were mine I'd be first checking the priority/divider spool (easy to do on the tractor). If that doesn't do it, I'd be looking again at both LH & RH filters to make sure everything's how it should be. If that doesn't do it, deeper diagnosis is required. Could be stripped splines between gear and piston pump as suggested above. Or problems in the piston pump/compensator. Or a host of other problems. But if it were mine I'd be crossing my fingers and start with the easy/common issue of the divider/priority valve spool sticking in its bore or lousy flow through the filter housings.
Edited by DanielW - 05 Mar 2026 at 8:07am |
DrAllis
Posted: 05 Mar 2026 at 8:00am |
If it was mine to repair, I'd just remove the piston pump and tear it apart. I'll bet there's a broken swash plate spring or something related to the swash plate de-stroke piston. You don't really have to drain any oil, but have plenty of plastic caps/plugs to plug holes to keep the oil where it belongs.
DanielW
Posted: 05 Mar 2026 at 9:13am |
I'm going to add one more point to my earlier reply: Earlier in this discussion it was suggested to take out and check the priority/divider spool to make sure it's shifting freely and easily. You then mentioned that you '...took the compensator out and it seemed like it moved ok...'. Did you actually mean the 'compensator' spool, or did you mean the 'priority' (or 'divider') spool? Two different things. And there are two compensator spools. While the Doc is likely right that it's time to pull the piston pump, as mentioned above I'd probably start by pulling and checking the priority/divider spool if you haven't yet done so. Quick and easy to do with the pump in place on the tractor.
First pic is the priority/divider assembly (on the side of the gear pump). Second is the compensator (on the front of the piston pump). ![]() ![]() Edited by DanielW - 05 Mar 2026 at 9:22am |
7060
Posted: 05 Mar 2026 at 5:30pm |
So is this surge chamber non filtered oil? Since the pto was removed on the rear end I used.. wondered if something in there could have got sucked into the line. Slim chance maybe, but it was a thought.
DrAllis
Posted: 05 Mar 2026 at 5:56pm |
Surge chamber oil is filtered, as the only way oil enters it is from the front after it has gone thru the right hand filter. If the surge chamber gets full, it spills over the wall into the rear end, again as filtered oil.
DanielW
Posted: 06 Mar 2026 at 7:11am |
This would be a question for someone like the Doc to confirm as I've never tried this myself: When I was working on my 7045 I was told by a local former Allis guy that you could check the piston pump function by over-filling the rear axle, such that the oil level was higher than the gap in the wall and spilled back into the surge chamber, so that the piston pump would have an oil supply regardless of whether the gear pump was working or not. I never did that though - I thought it a waste of time to throw good oil after bad. I had gone in with an inspection camera and found my gear pump drive gear was stripped. So I have no idea how much you'd have to overfill the rear end to spill backwards over the gap in the wall into the surge. And I'm not sure I'd want to try it, as you'd be introducing unfiltered oil to the piston pump. But maybe if everything was clean, and using new oil it would probably be ok? According to the Allis manual, the gap in the wall between the surge chamber and rest of the rear sump is 5" from the bottom, so you could theoretically measure/estimate oil depth above the sight glasses in the housing to guesstimate what level it would spill over at? I'd be curious to hear others thoughts on that. I wouldn't bother trying myself: If you get that far, it's evident something's awry with the pump anyway, so it's time to start disassembling (or at least to start more 'proper' diagnosis steps). The piston pump can be pulled off the front of the other two pump sections pretty easily. If you need to take off the gear pump, it involves draining the tranny sump and pulling the lower cover off it to access the intake to the gerotor pump and pull them as one.
Edited by DanielW - 06 Mar 2026 at 7:13am |
DrAllis
Thanks(1)
Posted: 06 Mar 2026 at 7:21am |
Well, he's kind of correct and then maybe not so correct. Overfilling the rear end by a 5 gallon pail or more would probably get into the surge chamber, yes. BUT, if the piston pump itself has mechanical issues, it isn't going to work anyway. Secondly, if the gear pump has failed, you won't have any power steering whatsoever. So, why try to diagnose beyond that obvious problem ??? Back when I was much younger, I could drop the belly pan and small fuel tank and have that piston pump off and on the bench in an hour or so. Overfilling the rear end and then having to drain it back out takes more than 10 minutes to do, so why bother ??
7060
Posted: 07 Mar 2026 at 7:19am |
We pulled the piston pump off yesterday and just took one off a parts tractor to put on it. That fixed it. Everything works, it’s showing about 1900psi on the gauge. I’m guessing the left filter being backwards starved the pump for too long. I was going to pull the old pump apart and see what was going on in it.
Edited by 7060 - 07 Mar 2026 at 7:20am |
