Tube or tubeless tires for my 1961 D15?
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Topic: Tube or tubeless tires for my 1961 D15?
    Posted: 20 Jan 2026 at 7:17pm
I have a 1961 D-15 Hi-crop tractor (s/n: 3801). I am getting ready to purchase new 12.4-38 tires for my 38x11" rims (see photo). These are not the current wheels on my tractor.
I'm trying to determine if I need to purchase tubeless or tubed tires. Are these rims compatible with tubeless tires? I'd prefer to go tubeless if possible.
I am planning on sand blasting and painting the wheels before adding the tires.
Thanks,
Tom
1961 D-15 Hi-Clearance
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2026 at 7:29pm
If your rims are solid and not rust pitted from being fluid fill tubeless tires will work without problems. Give your rums a good close look after sandblasting before you repaint them and spot weld any holes that might appear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2026 at 7:40pm
check the hole size where the valve goes... Make sure you get a valve that FITS.. or you might have to drill the hole alittlel bigger..
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2026 at 7:53am
I put a new pair of 18.4x34's on my 756D last summer, mounted tubeless. Just this week I put a tube in the right one. It just would not stay up. Very slow leak but annoying all the same. So the tube went in the tire/rim that looked almost factory new. And yes, I wire-brushed and painted the inside surface. No obvious puncture found in the tire. Left rim, which has some pitting, seems to be fine. If it starts to leak, it will get a tube pronto. Had it to do over again, tubes right out of the gate! Tried to save a few bucks, you know.
Edit; I should add that mounting them tubeless was not fun. Had to wrap a strap around and crank it as tight as possible to get them to 'take'.
Edited by IBWD MIke - 21 Jan 2026 at 7:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2026 at 7:57am
I just can't imagine going tubeless on a farm tractor rear tire or any farm implement tire for that matter.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2026 at 8:58am
i would never have a tractor tire mounted up tubeless even if it was just to parade and show
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2026 at 9:09am
I've got tubeless planter,grain cart,field cultivator 545B wheel loader and combine tires. Prefer tubes on tractors and recently had to mount a loader tire. PIA. Big rachet strap around center. Good way to get hurt trying to release ratchet.
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2026 at 6:41pm
Thanks everyone. I assumed that tubeless was the hands-down way to go, but apparently I'm mistaken. Glad I made this post! I figured being able to plug a tubeless tire was easier than having to replace a tube, if I ever had a puncture.
I'll be doing the mounting myself, so that is a consideration as well.  So now I'm thinking I need to buy a tube-type tire and a tube. As long as that will fit this rim I have, I'm fine with that. I just wasn't sure if my rim required a certain tire or not.
Thanks again,
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2026 at 8:36pm
If your tires are radials, be sure to get a radial type tube.  Not sure where I heard it, but I heard it...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2026 at 9:41pm
The one thing I’ve learned over the years for myself is let those that have the equipment and knowledge do the work for me. I’ve mounted a few tires but the aggregation wasn’t worth it. Pay the $50/tire and just pick it up and install it on the tractor. If the tube gets damaged while being mounted it’s on him. My local tire dealer gives me a great deal on tires and mounting because I always have him do my work, whether it’s tractor tires or vehicle tires. He wants the work to pay his bills/employees, and I like the less stress of dealing with it. It’s much safer also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 12:36am
In these difficult days of poor quality everything, I use radial tubes in bias ply tires. They are thicker and more robust and last longer. They also cost more, but you get what you pay for.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 5:55am
While some get away with mounting tubeless tires on rims designed for tube tire, it is not correct.  The rims in your picture are for tube type tires.  The bead seating area is different on rims designed for tubeless tires.
I agree with DrAllis on using radial tubes whether the tire is radial or bias.
Make sure you have the tube "right side up" when you install it.  The stems are offset and can/will rip out of the tube if installed wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 6:49am
Okay, give me the 'why' of that. Not trying to be smart, just trying to understand things better. Tires I put on that 756 are 'Tubeless can be mounted tube type'.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 7:00am
Anything I run off road I want a tube in the tires especially on older rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 8:16am
If rim is good and clean enough go tubeless.
We run tubeless on all our hay wagons.
Had a new rim for our D15. Tire guy came to put new tire on that and fix flat on 200. He said go tubeless on new rim. The tubes have become to unreliable. He always stood by new tire mounted if leaked but says the tubes are failing due to poor quality. With even good name manufacturer. The 200 ended up new tires but the rims weren’t in good enough shape to go tubeless so they got tubes. So far they have been good though.
Dad had a brand new tube out of box, for lawn mower, aired it up sprayed with soap and the whole thing foamed up with bubbles.
DanielW View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 9:04am
This is personal opinion, but I think what you use your equipment for and your land type should play into it. At our Southern farm in (comparatively) smooth land and only doing field work, a fair bit of our equipment is tubeless. I don't like it, but that's really personal preference. Most of the tubeless stuff does the job just dandy with no problem. As long as it's sealed right the first time.
At our Northern farm in the rough/rocky Canadian shield however, where we use much of our equipment in the bush as well as for field work, tubeless tires have always been a disaster. It only takes one case of you sliding and coming against a buried rock when doing field work, or a rock/stump in the bush to push it off the bead. Then you're pooched, trying to get the bead to re-seal enough to get home, or jack up and change a tire in an awkward, remote location.
I can't really see any reason not to put tubes in. As long as they're the correct tubes and installed properly. The problem I find these days is that few tire shops take the care needed to install tubes properly. They'll not clean the rim thoroughly, not dust the inside of the tire, not make sure it's not being pinched when inflated, and not do a deflate-reinflate after getting the bead seated. All of that is critical for a tube to last. But if done correctly, a tubed tire should last at least as long/longer than a tubeless one, and you don't have to worry about small leaks around a stem or bead that's no perfectly sealed. And you can work on rougher ground with more confidence that you're not going to cause a flat if you come against something that wants to push it off the bead slightly. I've taken to doing most tire work myself, just because it's impossible to find a tire shop that takes the care/time to put a tube in properly.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 10:07am
Thanks for the explanation Daniel!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2026 at 10:35am
Well said Daniel. Many yrs ago I pushed the twp backhoe rear tire off the bead on a ditch bank. Nearly impossible to get positioned and re aired.
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 4:13pm
This is what I was waiting for. Since my rims are for tube-type tires, that answers the question definitively. Tubes it is. I'll be sure to use radial tubes as well.
Thanks all!
Marvin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marvin75 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 2:25pm
I am so glad I I joined this forum just in this one thread I found why I keep ruining the tubes and that there is a whole procedure to it just not throwing it in and airing it up.
