Gpm flow to run 180 power steering system
Chuck in (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck in (wi) Quote  Post ReplyReply Direct Link To This Post Topic: Gpm flow to run 180 power steering system
    Posted: 19 Jan 2026 at 12:11pm
We put a 180 front end and steering orbital on a 301 swapped wd45 and going to run it off a belt driven pump wondering what size gpm pump we weold need to effectively run it would a d19 power steering pump have enough flow plus it would have a relief valve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 12:31pm
A healthy D-17/19 belt driven pump is about 8 GPM and has a 1600 psi relief valve built into it. Should work fine. At a slow idle, you might have to throttle it up a little bit for easier steering. Depends on how much weight is on the front wheels.
