D 14 carrier bearing |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1152 |
Topic: D 14 carrier bearingPosted: 18 Jan 2026 at 4:29pm |
I'm changing the brakes on the left side now. And I noticed the bearing's race had a score mark all the way around. The steel ring shims on this side totals 0.038. The other side was 0.022. I guess that's what was needed for pinion, ring gear backlash. But does the scoring on the race show its too tight. Edited by Tim NH - 18 Jan 2026 at 4:31pm |
DrAllis
Posted: 18 Jan 2026 at 6:11pm |
No. It ran fine before. If it was too tight, it would have failed by now. Don't change a thing.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90608 |
Posted: 18 Jan 2026 at 6:32pm |
what your seeing is minor damage from DIRT an CRUD in the oil that gets MASHED into the races... Roller bearings probably look the same... as Dr said, thats normal.
Tim NH
Posted: 18 Jan 2026 at 7:43pm |
Thank you Dr Allis and Steve for your reply's. I was completely relieved. I did notice that same color some what on the cage of the the bearing in that same area. Doing this brake job has been a can of worms.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2481 |
Posted: 18 Jan 2026 at 9:44pm |
The dull gray area is the normal wear pattern of the rollers. The thin discoloration at the edge of the race is also normal considering that nothing has been riding on that surface. The slight pitting is also normal for a bearing that is likely original. Change if you want, but the bearing should be replaced too. Personally, I wouldn't worry about it.
Tim NH
Posted: 19 Jan 2026 at 9:17am |
Thank you Lynn for your reply. I won't be changing either one out. I have more work to do on this tractor before spring.
