Allis 185
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Topic: Allis 185
    Posted: 16 Jan 2026 at 2:21pm
Does anyone have a handy part number for a block heater that'll fit in where a soft plug goes?Thanks
Gary(VA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 2:27pm
There’s a spot on the right side of the block towards the rear with a plate and two bolts. Agco sells a factory one for that location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 2:32pm
Thanks,found a KATS 30208 that looks like it will work.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 2:48pm
Yes, that Kats number fits my AC185 and 200. Nice thing is it's 1000W another brand is only around 600W. I can't think of brand or number.
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 5:12pm
PaulSamwel
Here is my 185 which has the block heater installed on the RH side of the engine left of the fuel filter.  The tractor was delivered new to our farm in 1975 with the block heater installed, probably by the dealer.  Not a great close up pic of the area, but you can see the electric cord hanging down just in front of the starter
Hope this helps with your project
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 5:43pm
Nice tractor!Looks like the one you have is above and to the right of the starter.The one I'm thinking of goes a little farther back in place of the plate towards rear of engine and above starter.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 7:24pm
Super nice 185 and incredibly close to looking like  it just came off of the Milwaukee truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 8:31pm
Lynn Marshall
Thanks.  I will never forget the day it arrived at our farm, on the Dealers truck.  Over time, rear tires replaced, new seat exactly the same, front tires upgraded from 7.50 and rims reversed, paint job and decals, every thing else factory (a few filters/muffler along the way).
Paul Samwel
I can see the access port you are planning to use.  The block heater will cause convective flow in the coolant passages to warm up the engine metal everywhere the passages go.  The engine metal will conduct the heat really well in all directions.  One port location might be slightly better for overall heat transfer result, but the top of the engine, and the combustion chambers should warm up plenty to achieve a good starting condition.
Other readers might have more info to share on best location for the heater element
My experience with block heaters, like the one on my 185, and the external tank type on my D17 III Diesel, is they work very well, heat the engine up to very very hot (close to operating temp) so starting is like a hot day in July!!!
Good luck with your install
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 6:24am
Very nice tractor,, at some point please put the right muffler on it,,, One Eightys and 185,s have it coming out one side,, just a peevee, of mine - not bashing,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 6:39am
That is probably a Stanley brand. The outlet is centered and also smaller in diameter than the OEM Nelson, which isn't available these days, unless A & W tractor Alex still has some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 6:56am
Probably so ,, I just always like the one forward open pipe,, looks cool,, lol,,
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 7:05am
I was lucky to get a Nelson for my 185 from Alex after the Stanley Dad put on it got bent in the derachio.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 11:13am
That is a beautiful 185.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 1:50pm
AllisFreakMN
Thank you
DougG, Dr Allis
Thanks for the tip.  I need to tell the story of the muffler..........(not trying to derail this excellent thread on block heater).
We had the dealer install a Year-Around Cab on the 185 in the fall of 1975.  The dealer welded an extension to the muffler stack so exhaust would clear the top of the cab.  The stack extension also served as a guide for operators who forgot about the cab height when going under a tree limb!!!..........numerous close calls
My father replaced the original muffler with the current and used the original OEM Nelson muffler stack (larger diameter sleeved over the new Stanley stack) and welded the pieces together - kind of a farmers solution.  It looked like ###%%% but got the job done!!..........good from far, but far from good
I removed the cab a few years ago and trimmed the muffler stack down to the current height to fit (barely) my garage door.  The extension is in my garage
The muffler works ok, but is a reminder of my father's attempt to manage costs
My brothers comment on the muffler every time they visit, comments not always favourable!!
Thanks for reading my rant about my nostalgic muffler
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 4:31pm
I am doing my 180 now. Hope it looks as good as the 185!
