175 pto lever
Josh N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Topic: 175 pto lever
    Posted: 15 Jan 2026 at 9:27pm
I have tractor spilt to redo the power director. Want to put new O ring on pto lever shaft. Does pin on the pto shifter fork just pound thru?   Someone mushroomed the end and can only pound one way. Can’t get a picture to post for some reason    Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 9:30pm
Drive it forward. If it's mushroomed, grind it flush and then drive it out. Replace with a grade 8 bolt and lock nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh N Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 9:34pm
That was my next step , thanks for the info. Is there also a O ring on the foot clutch pedal pivot stud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 10:04pm
NO.
