Turning Distro without changeing timing
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: Turning Distro without changeing timing
    Posted: 14 Jan 2026 at 2:48pm
For some reason my distro is 180 degrees off, so my tach drive isn't facing the right way. I "should" be able to turn it in increments of 60 degrees as long as I change which sparkplug is plugged where, right?
Or do I need to pull it completely and turn it and retime?
I will be timing the motor regardless, but I dunno really want find TDC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 3:27pm
Is it a D series tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 3:30pm
Sorry, 190xt
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 4:10pm
normally people want the #1 plug wire in a specific location.. if you dont care, then yes you are right.. rotate the distributor and cap 180 degrees and move the wires the same... It all depends on where the ROTOR is pointing and it will move 180 degrees with the distributor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 6:13pm
This much, I know. The distributor rotor/shaft cannot be turned 180 degrees. It only fits in the engine one-way, not two ways. So, with that in mind, proceed.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 10:58pm
Tach drive was forward on all 190/XT gas tractors as far as I know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 9:16am
Use a longer cable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 9:35am
I can't imagine the drive cable is supposed to point forward and turn around a 180 degree bend to the tach, that would cause significant wear on the cable. But I don't know for sure. It's also angled too close to the block cable physically won't screw on. So I would at least need to move 60 degrees.
The rotor/shaft won't be turning, just the housing and cap, so I shouldn't have issues with that.
The #1 spark plug wire will be in a different hole in the cap, but will be in the same place relative to the rotor. The same absolute place in space.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 10:11am
If someone has an Owners manual to an early 190/190XT, I'm sure there is a picture of the left side of a gasoline engine and that would verify how things were positioned. The later model tachometers were driven by the alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 10:18am
Looked through, only shows the diesel left side.
This page was generated in 0.246 seconds.
