AC 185 tractor
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Topic: AC 185 tractor
    Posted: 13 Jan 2026 at 5:56pm
I bought a non running AC 185 tractor for cheap.Previous owner says new IP.Put in fresh fuel,no start and barely any smoke coming out the stack.Fuel at injectors.Has decent compression.Pulled injectors and nozzles are plugged.Was going to clean or replace tips.Seems like everybody wants to sell the whole injector.Where can I get just the 74007218 tips?Thanks
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 6:08pm
A diesel pump shop should be able to get them for you.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 10:43pm
Just in case you don't know the fuel stop has to be pulled out not pushed in like most tractors for it to get fuel, run etc.
