Drill Fertilizer Gate Openings
Pointer Hollow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Topic: Drill Fertilizer Gate Openings
    Posted: 12 Jan 2026 at 7:58pm
So on my 11x7 drill I am going over everything with lots of TLC before planting time.  The fertilizer area is in good condition considering how old the drill is.  My question is this.  With the gates fully closed, there is still this small opening.....is this normal?  If so, does the fertilizer normally "clump a little" and seal this off or is it always going to be dribbling out?  I checked and I don't see any binding and after a little lube everything functions smoothly.
Thoughts?
Edited by Pointer Hollow Farm - 12 Jan 2026 at 7:59pm
dr p View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 5:14am
There should not be a hole
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 7:57am
My thought: don’t run fertilizer through your drill.
You are free to do as you please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 11:41am
Most likely I will not unless I need to. I figured since I am going through it before season, I would get it operating the way it should.
This page was generated in 0.316 seconds.
