Can my Maglight be saved,,,,??
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Can my Maglight be saved,,,,??
    Posted: 12 Jan 2026 at 4:34pm
 Howdy,,,Here's hoping someone can help with a small Oh- oh,,,,
 I have one of the 4 battery Maglites that took a dive and started growing some grayish gookies around the batteries and just do not want to vacate the inside of flashilight,,,,,!!!
 I scraped most of the gookies out but still cannot get batteries to move to try to remove them,,,,
 Anyone got an idee of what to use to maybe remove this gunk,,,,,???
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 5:08pm
Joe, Im sure someone will come along with some good advice. I had three of them, and had trouble with all of them. Fantastic when they were new, but, even though I changed batteries regularly, whether they needed or not. still got corrosion, and broken switches.
I gave up on them.
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 6:51pm
I'd say a slide hammer with a screw on the tip, drill a pilot hole in the battery, screw in the slide hammer and yank away.  Don't do like my brother did he was too cheap to buy a drill bit long enough (stuck battery was down 2 or 3 in the stack) to reach the stuck battery, and sized for the screw in the SH...Wink
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 7:22pm
Unscrew the adjustable light reflector, remove the retaining snap ring, pull the rubber switch cover off, insert a very small allen wrench (can't remember the size) through the switch hole and loosen the screw holding the plastic light holder/batter connection, hold the switch down to clear the body and the plastic part should slide out the light end.  At least taking it apart will give access to both ends of the batteries.  I have taken a couple apart completely and found the battery acid coating the plastic part.  Cleaning is not fun and have tried several ways with mixed results.
IB (restoring), MF GC1705, MF 2705E
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 9:21pm
If ya got one of them Somali day care centers, your wallet should be able to hack a good slathering of Dielectric Grease. It would be the only thing I'd know of to prevent it. Possibly try rubbing a Mexie skull.
Edited by Walker - 12 Jan 2026 at 9:30pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 11:42am
We all your the go to guy to fix anything even remotely fixable. But sometime Confused why? The flash light world has come so far with the new LED bulbs.
My nephew works for Surefire, about 20 years ago he was giving us their new (at the time) supper bright made blind the bad guys flash lights. So small I lost a few. But they took special batteries, got him to give batteries to. Big smile
But my Wonderful has flashlights stashed all over the house. Which are getting used a lot more with our electric company installing all the new wildfire safety shut offs. The power is off at least every other month.  Anyway I grabbed one of hers, the 2 D size battery model. Must not have a batteries in it, was so lite but I hit the switch and it was like the sun had come up. I think it was one C size battery in it. Then the NRA sends my free gift for staying a member Big smile a little bitty flashlight that takes one AA and makes light like your old mag light.
Wink So other than you want a club, or the principle that no device wins. WHY ARE YOUN BOTHERING. OK I guess I do know O'l Joe fixes it because he can. So carry on don't let this be the device that beats you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 1:02pm
I got one of them Mag Lights that takes two AA batteries... Battery died and STUCK in the case just like Joe said... I got a couple pair of pliers and unscrewed the bulb case on the top and could see the circuit board and contact for the battery to hit.. Bulb buried down in there somewhere... With that off ( what a pain, it was GLUED and SCREWED).. i poked the batteries out.. Very minor corrosion, but STUCK TIGHT... Ran a 9/16 inch drill bit thru the case ( drill about .010 smaller than battery) and reamed it out good.. Now the batteries slide thru again.......... Reassembled and ready to go.... They did NOT make that bulb / head / circuit board housing to come back apart easy !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 12:24pm
Good advice already posted on disassembly of the light. If you can’t get it cleaned up and working properly, I may have a replacement which I could ship to you. Those Maglites not only have a bright light, they make good attitude adjusters also. The new led lights lack that heft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 3:42pm
I remember when they were called kel lites, cops carried them, and when they hit someone with 'em, the resulting injury was called a keltusion...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 4:57am
Still have three Mag light 2 D cell units, one is in my Tool box, one in my Ford PU and the last in the KW. Bought one a Red One thirty plus years ago. Second one found wedged in a flywheel housing on a Trailer Carrier nosemount Refrigeration unit, was Fubar so sent into Maglight to see if could repair, sent me a brand new one for free. Last one received as a gift just at nine years ago for retirement. All three been updated to LED bulbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 6:18am
DJ, tried to reply to your pm but the site wouldn’t let me type in a message. I will try again later today. I also have an email address listed if you want to try that.
Allisbroke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisbroke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 7:43am
Does anyone recommend a particular LED flashlight that (1) doesn't blind every animal in a 50ft radius (2) doesn't waste the LED's efficiency/battery life blinding them, and (3) doesn't shut off at the worst moment with zero warning? These things should be great but as usual seem to miss the mark in taking advantage of new technology. Would be nice to skip the popular seizure strobe setting too. Thanks for any suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 8:15am
LEDs work on Low Voltage, produce roughly same lumens across a range of voltage from 2-5v dc, with batteries going dead, will not ever get a warning when the lamp will go out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 3:36pm
Just bought a couple good ones.  Both ryobi, one is a clamp on 18V, snake light on top, dimmable (high/lo), and the led light can be focused.  The other one is a little thing, can be attached to a 2 x 4, or has (weak) magnets, for mounting to a iron or steel, 3 way switch and has its own li-on battery, drawback is that the battery has to be charged with a USB connection...Wink
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2026 at 9:53am
I have had more than a few multi-cell Mag-Lights to get forgotten about in some truck or other and the batteries leak and swell up.
I have always been able to unscrew both ends for access to the problem.
Soaking everything with some sort of knocker-loose seems to help; but, either driving out or slide-hammer pulling out the corroded batteries is always required; the slide-hammer with a deep-threaded screw seems to work best.
A brass-bristle wire-brush on a long drill extension works wonders to brush and polish away the corrosion inside the tube.
Wear a good respirator as you probably don't need the poison dust inside your lungs to kill you a few years later.
I have found that NiMH Rechargeable batteries do not have all the leaking corrosion problems associated with Alkaline and Ni-Cad batteries, nor do they swell up.
I have up-graded all my Mag-Lites to LED bulbs and brightness, penetration, and battery life is much better.
As good as Mag-Lights are, and they are GOOD, they always have had some short-comings; the worst one being that they are round with no flats and will roll away as soon as laid down.
I have a 3-D-cell Harbor Freight version that someone gave me for Christmas that is every bit as good as a Mag-Light and has addressed all the short-comings of the real deal.
The end cap on the Harbor Freight is somewhat larger in diameter and octagonal, plus the bulb end is octagonal; it don't roll away.
The Harbor Freight light came as LED and did not need be converted.
The Harbor Freight light is every bit as well made and O-ring sealed as the real deal.
As for the AA and AAA Mag-Lites, I have found that very few rechargeable NiMH batteries are slim enough to slide in the barrel; most rechargeable batteries are just two large in diameter and will not fit; I have probably twelve different brands of NiMH batteries and only two brands will fit inside the Mag-Lite tubes, Eneloop and Harbor Freights Thunderbolt.
The generic copy-cat AA and AAA versions don't have this problem and any old rechargeable NiMH battery will easily slide inside the tube.
As for my D-cell lights, I have some Harbor Freight D-cell NiMH rechargeables that are at least thirty years old and still going strong, having been recharged countless times; they last just as long on a charge today as they did when new.
Somewhere around here, I have a bunch of AA-to-D adapters where three AA make one "D"; I need to tear this place apart and find them and see how the AA in adapters compare to actual "D" cells.
I read somewhere or saw on a You-Tube video where some guy tore into a particular brand of "D"-cell and inside were three AA; the same guy tore into some 9-volt transistor batteries and found six AAA inside.
The three AA inside a "D" does not hold true with every brand as the ones I have had to destroy to get out when stuck inside were all of singular construction.
This page was generated in 0.204 seconds.
