Help me D21 shopping
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: Help me D21 shopping
    Posted: 11 Jan 2026 at 4:03am
How is the market doing on D21s. I have let the bug get ahold of me and have narrowed down my search and found a very early SN  21 that is absolutely stunning.
Part of me says get all over it, your not getting any younger,67, I have worked and saved all my life, saw parents lose 900 acres in 1984 and that changes outlook.
A other part of me says why.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 6:22am
I have always wanted one. D17,180,200,7060 is my background. Started looking recently and found out it's a slippery slope.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 7:01am
The worms are going to eat you at the same speed when you die if you buy it or not. Do what is going to make you happy. Financially, i don't think it is a terrible investment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 7:42am
Some have been kept up and are pretty sound. Others are a pig with a coat of new paint slapped on them. Beware !!    A "very early" serial number (to me) would be a non-turbo 103 PTO HP model. If it has the turbo/engine oil cooler kit added on, that's what it is.....an added on turbo kit from A-C which was offered but it wasn't on it from the factory.  The engine s/n tag is on the left rear side of the block just above the starter. The chassis s/n is very close by, stamped into the bell housing. If the chassis is D21-1001, the engine is probably 3D-1003 or 3D-1004.  Those engines in 1963-64 were almost exclusively used in the D-21 tractor. Finding an engine s/n that indicates it is probably the original engine (to me) makes it worth more $$$$$$ when you go to sell it on your estate sale. I feel a PTO makes them worth more, as does a factory 3-point hitch. Make sure the top link anchor holes aren't broken off as that is a deduct in value.   18.4 x 34 tires (for me) are a huge deduct. 24.5 x 32's are muscle tractor material.  18.4 x 38's are in between.  I recently saw one for sale that originally had 18.4 x 34's when new, but somewhere in the last 60 years had the rims widened and 20.8 x 34's mounted. They stand as tall as 18.4 x 38's (a good thing) but resale wise, better than the 18.4 x 34's but not (to me) as valuable as the other two sizes.  A curved front "starter" weight is a great thing !!!   Fenders skirts also are desirable.   Rear axle seals that aren't leaking a puddle wherever you park it is also a good thing. If it runs well, and you drive it....you'll get hooked. They were one of a kind !!
Edited by DrAllis - 11 Jan 2026 at 4:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 7:51am
This is what iam talking about. I can't hardly believe what  I see when I look into a mirror. All of a sudden iam what I called an old man.  But here I am, still taking what life has thrown at me, lemonade out of lemons I have several times.
I don't want to bring bad luck as bad luck has followed me at times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 10:23am
Guy in Iowa had one for sale- he paints them and does a great job- Id trust that one,,
Edited by DougG - 11 Jan 2026 at 10:24am
