OIL WEIGHT
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Topic: OIL WEIGHT
    Posted: 17 Nov 2010 at 7:34pm
Allis Chalmers B - what weight oil is correct?  I was all ready to put in 10W30 and I started looking through papers that the previous owner gave me and in pencil was written 10W40.   Is it opinion or is there a correct designated weight.  I always thought you can't go wrong with 10W30.  The tractor is just a play toy and is not going to be worked hard.  Something to keep me in the garage and not in my wife's hair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 7:56pm
According to Allis literature a straight weigh non detergent is what they called for. Now days I use 10W30 in my 45 cause I use it year round. My B only gets used to mow with and has many hours on it so I run straight 30W in it.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 8:03pm
Fred
I use 10-30 in my tractors with no problems
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 8:08pm
Depends on the age and the condition of the engine.  If it has been some time since the engine has been overhauled then I would definitely use 30W NON DETERGENT OIL.  The reason being that the detergent oil has the ability to clean out the gunk in an older tractor.  While that is fine with an engine that has been recently overhauled it may not be so fine with a unit that has an engine that has not been recently overhauled.  The gunk could be keeping the tractor from burning or leaking oil.  We had more than one situation when we were selling.  We always put non detergent oil in the engines of used tractors.
Congratulations or obtaining my favorate.  Take good care of it.
Good luck!
Bill Long
ps:  Do not hesitate to ask if you need anything
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 8:32pm
When those tractors were new, all they had was straight weight oil.
When detergent oil was devloped, it did clean up engines, but also kept them clean, and not only did that but it cut back on the corrosion of copper/silver against steel of the bearings on the crankshaft when there was moisture in the oil. And with the new oil engines in cars went from needing rebuilds at 35,000 mile intervals to needing rebuilds at 100,000 mile intervals. The use of short stroke engines had something to do with that longevity also.
I'm of the opinion that using a nondetergent oil is abuse of an engine.
10W30 and 10W40 work where the books used to call for 10 in the winter and 30 in the summer. There have been some problems with 10W40 in air cooled engines that got the oil really hot where it would gel, so 10W30 is preferred in that case.
Gerald J.
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 8:42pm
It is a 1952 B and I have no idea to any of it's history.  It's been only living with me now long enough to clean and paint it.  The oil I removed was very dirty.  As far as  a overhaul there were some receipts for rod bearings and the head was clean of all paint leading me to believe that the head was off anyway but I don't think that was very recent.  There was a very small amount of slug under the rocker arm cover.
 I understand about using detergent oil in an engine that has always had non detergent oil.  I know this from my experience with antique cars that were made before detergent oil.
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 5:42am
I use mobil1 oil & add can of restore to oil,my El camino had 275000 miles when I sold it & is still running with this mix.
My I40 gets same treatment & seems to wok fine,comp @ 110 lbs & hardly any smoke
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 11:00am
Why do some people freak out if they hear of putting detergent oil in an old briggs even if it was clean? they act like it will cause it to fail.
B212,716,two 314H's,WC,WD,D19,190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 11:05am
If it were mine, and I knew it had sludge in it, I would remove the valve cover and oil pan and use something like brake cleaner and carefully wash it out. I have been putting Mobil1 0W-20/BG Product's MOA in my CA to make it easier to start in the cold at least 10 years now. I figure I can afford to spend more on oil for it since it only gets changed about once a year due to getting very few hours.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 11:56am
Just ran across this forum and joined due to my history of working in the tractor engineering department at West Allis and love of old tractors (grew up on a farm in the 40's and 50's).  Like several other "motor" related forums that I participate in, oil is a frequent and interesting subject.
You probably will be fine with most any oil you use---------if you don't start it often or in cold temps or put much load on the tractor.  However, if it were my tractor, I would use Mobil 1 5w-40 diesel oil in it.  This oil is also rated for spark engine use, will provide quick lubrication on start-up, and provide a little extra film strength if there are some worn parts in the engine.  It also has more zinc additive in it for bearing protection then some of the newest oils.
If the engine is full of sludge (unlikely if recently worked on), the sludge will create problems whether you use detergent oil or not.  Unless I was going to re-sell it quickly, I would prefer to get an engine clean using a good detergent oil and then deal with any problem that might show up.
The best thing is to put in a good modern oil, and then do an oil analysis (less than $30) when you think the oil should be changed.  That will tell you something about the condition of the engine and whether the oil really needed changing at that point or not.
My 2 cents, anyway.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 12:30pm
5W-40 synthetic will find cracks and old gaskets that 10W40 won't. I have a VW Golf and the factory would like 0W40. It disappears too rapidly, to need changing with 75K on the engine. Part is leaking out a crack in the diecast oil pan. 5W30 semi synthetic stays in a lot better.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 3:15pm
Gerald J.
That's hard to understand.  Both these oils will be 40 weight oils at operating temperature or about 15-17 cSt (centistrokes) at 200 degrees.
At 50 degrees, both the 5w and the 10w will be much thicker.  The 5w will be around 280 cSt  and the 10w will be about 460 cSt.
To put it another way, if either the 5w or 10w oil leaks when setting, they should both pour out when at operating temp.  The only thing that be happening is that the cracked oil pan might, just might, seal itself up as the engine heats up and the metal expands.
You have to admit that choosing oil based on a cracked oil pan rather than what's best for the bearings may leave a little to be desired.
Edited by 427435 - 18 Nov 2010 at 3:16pm
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 4:46pm
I'm sorry I mentioned 30 W non detergent oil now. The original post said the previous owner was using 10W40 and Fred wanted to know if he could use 10W30. The answer is yes.
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 12:03pm
First off I want to thank everyone for their advise and thoughtful opinions.  Well, here is what I decided to do.  After draining the oil and waiting until it stopped dripping, so it wouldn't go in my face, I looked up in the drain hole and could see a relatively clean engine.  I took an acid brush and bent it in a U shape, put it in and explored. I found that the sludge was confined to the lowest point of the pan.  That saucer like part of the pan where the drain plug is.  I kept on wiping and cleaning with the brush and then using my squirt oil can I pumped oil in the hole and working it with a bottle brush until that oil came out clean. Then I put the plug back in and poured in a qt of oil that I had on the shelf.  I let it set, drained it out and it came out clean.  I now have petroleum oil 10W30 which I will change sooner.  Eventually I will go to Mobil 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 3:30pm
Never thought of using brush to clean out bottom of pan,bought new pan gasket for I 40 & getting ready to drop pan while I have tractror apart for painting(glad son made me buy impact wrench)
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 7:37pm
" That's hard to understand.  Both these oils will be 40 weight oils at operating temperature or about 15-17 cSt (centistrokes) at 200 degrees.
At 50 degrees, both the 5w and the 10w will be much thicker.  The 5w will be around 280 cSt  and the 10w will be about 460 cSt."
 the way i was told that an oil that
say 5w 30 is that when the oil is cold
it will act like a 5 wight oil but when
it get hot it will act like a 30 wight oil
i know that your think that when the
oil get hot it get thin  not so they tell
me that sense they used polymer in
the oil the polymer is per say plastic
they take a piece of it and roll it up
in a ball thus when it cold it get
small and when you heat it up it
expand and get bigger there for
the oil get thicker when it heat up .
best  is to put in a good modern oil
then the old straight weigh non detergen
IMO   HTH
B:-)    Dnoym
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 7:49pm
There was a positive comment about using Diesel oil in a gas engine. Any disadvantage to this ? Additives that are good, bad or no effect ? Looks like all oil is good so shop the price ???
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 7:51pm
here some thing i found on the net
At cold temperatures, the polymers are coiled up and
allow the oil to flow as their low numbers indicate.
As the oil warms up, the polymers begin to unwind
into long chains that prevent the oil from thinning as
much as it normally would. The result is that at 100
degrees C, the oil has thinned only as much as the
higher viscosity number indicates. Another way of
looking at multi-vis oils is to think of a 20W-50 as
a 20 weight oil that will not thin more than a 50
weight would when hot.
Multi-viscosity
Multi viscosity oils work like this: Polymers are
added to a light base (5W, 10W, 20W), which
prevent the oil from thinning as much as it
warms up. At cold temperatures the polymers
are coiled up and allow the oil to flow as their
low numbers indicate. As the oil warms up the
polymers begin to unwind into long chains that
degrees C the oil has thinned only as much as
the higher viscosity number indicates. Another
way of looking at multi-vis oils is to think of a
20W-50 as a 20 weight oil that will not thin
more than a 50 weight would when hot.
Multi viscosity oils are one of the great
improvements in oils, but they should be
chosen wisely. Always use a multi grade
with the narrowest span of viscosity that
is appropriate for the temperatures you
are going to encounter. In the winter base
your decision on the lowest temperature
you will encounter, in the summer, the
highest temperature you expect. The
polymers can shear and burn forming
deposits that can cause ring sticking
and other problems. 10W-40 and 5W-30
require a lot of polymers (synthetics excluded)
to achieve that range. This has caused problems
in diesel engines, but fewer polymers are better
for all engines. The wide viscosity range oils, in
general, are more prone to viscosity and thermal
breakdown due to the high polymer content.
It is the oil that lubricates, not the additives.
Oils that can do their job with the fewest
additives are the best.
Very few manufactures recommend 10W-40
any more, and some threaten to void warranties
if it is used. It was not included in this article for
that reason. 20W-50 is the same 30 point spread,
but because it starts with a heavier base it requires
less viscosity index improvers (polymers) to do the
job. AMSOIL can formulate their 10W-30 and 15W-40
with no viscosity index improvers but uses some in
the 10W-40 and 5W-30. Mobil 1 uses no viscosity
improver in their 5W-30, and I assume the new
10W-30. Follow your manufacturer's recommendations
as to which weights are appropriate for your vehicle.
D:-)     Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 8:12pm
The hazard reported for 10W40 is in engines like air cooled engines that get really hot. Then the polymer changes and can turn that oil to grease or a solid that doesn't flow well.
Briggs was one of those that didn't like 10W40, but now has adopted synthetic, especially if you buy it from them.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 8:38pm
Just curious who is voiding warranty over 10-40? On late model automotive engines you can cause problems from not using to proper grade because of some non lubricating functions that oil is used for. Cam phasers, hydraulic chain tensioners, high pressure oil controlled injection on Navistar diesels just to name a few.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2010 at 11:17pm
Gerald J.
A wide range multi-weight oil can cause problems in air cooled engines if it is a dino oil.  That's because a lot of viscosity index improvers (those little balls that unwind as mentioned above) have to be used.  This is what makes the base 10w oil act like a thicker oil as the oil heats up.  Heat and use will break those VI improvers down and the oil becomes a 10w-20.  A 20 weight oil in an air cooled engine is not a good idea in warm ambients.
A good synthetic 10w-40 oil doesn't need or use any VI improvers------and it remains a 40 weight oil even after a lot of use and/or heat.
The new Briggs chart just finally caught up to synthetics.  Took them a long time!!
Mark
GTH-L Simplicity
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 6:24am
This is pretty interesting. But now where does the Lucas oil treatment come to play. What does it do to the oil. I sell it where I work and lots of people swear by it and I have started using it myself. I drained the oil out of one my vehicles the other day and it had  lots and lots of miles on the oil change  (I get behind sometimes). The oil was black as it could be but still had a nice slick feel to it. The oil was a generic we sell called fleetguard with a pint of Lucas added.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 9:17am
You won't like this, but that's what is called "Mouse Milk" by lubrication people.  Use a good oil from a reputable supplier------you don't need anything else.  If you're really into oils, do an oil analysis when you drain your oil.  That will tell you how good the oil has been, whether it really needed changing or not, and what's going on inside your engine.  One place for this is http://www.blackstone-labs.com/ .
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 9:52am
Check the MSDS for Lucas and the other motor honeys. All it is is thick  oil. Nothing more, nothing less.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 10:17am
BG Product's MOA is an exception to that. According to their people all it is is the additives that are found in high quality motor oils. Just more detergents, zinc, and other friction modifiers. I work with a guy who races 4 stroke go carts. He runs straight MOA and claims that little trick is worth another 200 RPM's and 100 degrees cooler.
