tap for exhaust manifold |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25201 |
Topic: tap for exhaust manifoldPosted: 08 Jan 2026 at 7:34am |
OK, trying to clean up the garage and found some big taps, got me thinking, pretty sure some here posted what size tap can be used for threading the exhaust manifold on a D-14 or maybe a B ? I just hate to toss out these taps IF that can be used by someone. Jay update. finally found one of them, says 2" , 1 1/2 NPT. Has 2-3 missing teeth otherwise in VGC !
Edited by jaybmiller - 08 Jan 2026 at 3:37pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4270 |
Posted: 08 Jan 2026 at 7:44am |
Not sure about a 14 but a D-17 takes a 1&1/2" pipe tap.
I don't scrap a tap until it's broken generally speaking. Don't tap enough holes to make one dull these days.
Les Kerf
Posted: 08 Jan 2026 at 9:34am |
I bought a 1-1/4" pipe tap specifically for my Model C manifolds, works great!
KJCHRIS
Posted: 08 Jan 2026 at 2:37pm |
1 1/2" npt on D17 S3 gas.
2" npt on AC 180 / 185. IHC M- 560 gas.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90636 |
Posted: 08 Jan 2026 at 4:56pm |
keep them around.. those come in handy when working on OLD PLUMBING drains... also bilge pump - irrigation pumps suction and discharge ports.. old rusty pump cases can be repaired..
AveryD12
Joined: 05 Mar 2018 Location: Foxworth.MS Points: 162 |
Posted: 08 Jan 2026 at 6:15pm |
Can a D12 III manifold be tapped? I haven’t had much luck with the original setup. The muffler stabs into the manifold and has two bolts that bolt thru a flange on the side (for lack of a better term) into the manifold. If it can be threaded and a pipe nipple screwed into it I could secure a muffler with a muffler clamp
IBWD MIke
Posted: 09 Jan 2026 at 6:36am |
I would think they could be. You would have to check the I.D. and see if it's close to tap-drill size. It might be interesting trying to cut threads into cast iron that has been heat cycled a zillion times.
