D-15 series II |
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 583 |
Topic: D-15 series IIPosted: 05 Jan 2026 at 6:27pm |
D-15 series II with factory 3 point hitch - are the lift arms cat. 1 or cat. 2? If cat 1, is there not enough iron in the set up to handle cat 2 equipment? Has anyone ever exchanged the cat 1 arms for cat 2 arms? What might the consequences be?
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1167 |
Posted: 05 Jan 2026 at 6:54pm |
i have a D-15 series II with factory 3 point hitch. They are lift arms cat. 1. They are original. It was one of the first models built in 1966. Hope that helps.
DrAllis
Posted: 05 Jan 2026 at 9:46pm |
All D-15 tractors were equipped with a category "1" three-point hitch. It was (for the most part) quite light-duty in design and if used extensively on a moldboard plow for example, didn't hold up well at all for many owners. Broken draft arms and bolts that held the torsion bar up underneath the tractor would work loose and then a catastrophic failure could occur. Changing the draft arms to a heavier Cat #2 design might solve that issue but not the torsion bar bolts or framework. There are lots of previous posts about this subject on this website and mostly negative.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1294 |
Posted: 06 Jan 2026 at 8:28am |
The D15 series 2 was available with a 3pt carrying system. Allis-Chalmers inadvertently advertised it as a hitch.
The snap coupler is a hitch. |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1547 |
Posted: 06 Jan 2026 at 10:33am |
The whole world referred to it as 3-pt hitch. Including the inventors - Ferguson and Massey Ferguson! Semantics - Lol!!!!!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5212 |
Posted: 06 Jan 2026 at 10:47am |
The D15II could be either Cat I or Cat II.
Mine had the Cat II 3pt when I got it. It also have been welded and patched many way and 4 the holes in the bottom of the transmission case and lift housing where about ruined. I was able to repair the 2 in the transmission, but the 2 in the lift housing had already been enlarged and had those threads pulled out. What a pispoor design, it should have been like the D17 IV. After making the repairs it is now a SnapCoupler tractor and nothing has loosened up since I've owned the tractor.
Edited by PaulB - 07 Jan 2026 at 3:16pm |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7585 |
Posted: 06 Jan 2026 at 2:33pm |
I have 2 D15 IIs with factory 3 point. Both are Cat 1. One barely has a scratch on it, the other has been welded many times in many places. Definitely not one of AC's best efforts. If you plan on doing lots of 3 point work, get a D17 series 4 with factory 3 point - they are bulletproof.
DrAllis
Posted: 06 Jan 2026 at 5:17pm |
I had to go and dig up my D-15 S2 literature books. The book dated July of 1963 says Category #1 three-point hitch. The newer book dated Sept of 1966 says Category #1 is the standard three-point hitch and Category #2 was OPTIONAL equipment. I've never seen a Cat 2 hitch on a D-15 S2. Were the balls just bigger?? or 2-hole sized balls?? Sounds like they didn't beef it up any from Cat 1.
PaulB
Posted: 06 Jan 2026 at 7:52pm |
The balls just had bigger holes and a bushing was used if it was desired to hitch to a Cat I implement. This is shown in the parts book I have (March 1982). The only parts different for the Cat II 3pt hitch are the draft arms and the implement end of the top link. |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4982 |
Posted: 07 Jan 2026 at 7:42am |
Biggest problem with the D15sII is people using it like it was a D17 . I believe Allis Chalmers put the light weight Cat 1 3pt on it to keep the user from trying to use it for more than it was intended. Yes a heavier 3pt like the 17,19 ,185,190 would have been stronger and more dependable but probably would have led to drive train ,rear end and transmission problems. Stick with the cat1 and use the tractor as intended.
Never seen a D15SII with cat 2 Edited by Pat the Plumber CIL - 07 Jan 2026 at 7:43am |
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5349 |
Posted: 07 Jan 2026 at 10:34am |
Dad’s 1968 Series II is cat 2. He purchased it new. We have never had a failure in the 3 pt. We do however keep check on the bolts.
Leadoff
Posted: 07 Jan 2026 at 11:18am |
D15 Enthusiasts
IMHO the D15 served it's owners well IF OPERATED WITHIN THE ALLOWABLE LIMITS OF THE DESIGN OF THE TRACTOR This thread, and numerous others on the Forum, have the information well documented The D15 design limitations..........(if exceeded) - TPH arms, frame mounting bolts - TPH drawbar support and mounting bolts - transmission shifter/grinding gears/subsequent jumping out of gear (D17 bulletproof) All of the above were the result of exceeding design limits, operator abuse, or probably in most cases lack of knowledge Now, the pot is calling the kettle black here, as a teenager on our dairy farm in the late sixties, operating a brand new D15 Series II, I was guilty of the second and third infractions shown above We/I smashed the cast iron drawbar support hauling a NH manure spreader with way too much vertical load when the rear wheel dropped down into a pothole and bang #####%%%%% If I had a dollar (CDN) for every time my father heard me and my brothers grind the gears on the poor D15 Final point in the D15 favour, we often used the D15 to pull our Allis Chalmers 2200 10 ft disc (3rd Low) to free up our D17 for plowing, and it performed this duty very well, but we were probably overloading the tractor Some D15's were well looked after and survived ................ Very similar to other machines (cars, trucks, tools, etc) I look forward to every time I can jump on mine and go
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3148 |
Posted: 07 Jan 2026 at 11:46am |
The bolts that anchor the 3pt to the tractor are 1 inch long,but the threaded holes they bolt into are 2 inches deep.Why AC didn't use a longer bolt is a mystery to me.Anyway I got 4 grade 8 all thread rods and ran them to bottom out coated with red Loctite.They won't budge and never had a problem again.
DrAllis
Posted: 07 Jan 2026 at 3:49pm |
I haven't laid underneath one with a 3-point hitch, but if one made a couple of 3/8" or 1/2" thick flat straps 3 inches wide, to attach as close to the outside of that torsion bar framework as possible and go forward at an angle to where the two rear 3/4" bolts are for the snap-coupler spring frame, that would support the torsion bar immensely where it needs some help and be using two new chassis holes to spread out the load. Making these braces a perfect fit would be best, or maybe a large turnbuckle on each one to place the torsion bar under a little tension. This would be accomplishing the same thing a model 200 and 7000 have to strengthen their lower hitch area, and theirs are adjustable with a nut on each side.
AC720Man
Posted: 10 hours 47 minutes ago at 8:45pm |
Gary I like your upgrade! Wasn’t aware of the depth difference. We just made sure the bolts stayed tight. Only noticed bolts being a little loose 1 time while changing transmission oil. That’s a good idea and I will see about getting that done over the winter after I get the D14 done.
Edited by AC720Man - 10 hours 40 minutes ago at 8:52pm |
Gary Burnett
Posted: 5 hours 39 minutes ago at 1:53am |
McMaster Carr had the all thread rod and I used those self locking nuts with the nylon inserts
