Just a matter of curiosity, irrigation |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: Just a matter of curiosity, irrigationPosted: 04 Jan 2026 at 9:09pm |
Thanks for all the input. Like I said, just curious. Ted, pretty good explanation.
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 161 |
Posted: 04 Jan 2026 at 5:47pm |
To keep it simple, I'll start off by saying there are exceptions to most everything, and newer control systems that use computing power. Most in my area run on 480v 3 phase with a transformer to supply a 110v control circuit. The 480 is swapped at the pivot to run either forward or reverse. There are seperate wires that go out for the forward and reverse control circuits, and each span has a control box with a contactor for the 480 and two microswitches that run on a cam that is attached by linkage to the next span. one of the microswitches has the forward and reverse conrol cicuits wired into the normal open and normal closed posts, and the common runs the contactor. When the next span out moves far enough it trips the switch so it moves until the switch is open again. The other microswitch is the safety circuit, if for some reason things don't move it opens the circuit and the machine shuts down. Most machines 20 years ago(when I took classes) were built so if 110v was sent back to the pivot on the control circuit that wasn't being used it would reverse the machine. Speed used to be controlled by a simple timer, most made now use a computer and can be set up to change the speed in different areas of the field.
T-L macines run on hydraulic, and have flow control valves on each span to keep them aligned, and the only one I had much experience with used a flow control valve at the end to control the speed. Again most of my information is from many years ago, and there are several exceptions. I hope this answers your question. Ted |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35690 |
Posted: 04 Jan 2026 at 5:33pm |
Most Pivots around here have Water Driven Motors to Chain Drive Axle Wheels.
DougG
Posted: 04 Jan 2026 at 5:26pm |
Poor Ole farmers,,,,, getting those checks,,
Edited by DougG - 04 Jan 2026 at 5:26pm |
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1619 |
Posted: 04 Jan 2026 at 3:20pm |
Each tower moves independently. There are limit switches that only let each one move so far. They are not always in a "perfect" straight line, but they are close. The speed can be controlled as to how much water they want put on the field. Most can be controlled from a cell phone nowadays. I am literally surrounded by them where I live. Valley, Zimmatic and T-L are the 3 major brands around here.
Edited by AllisFreak MN - 04 Jan 2026 at 3:22pm |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 04 Jan 2026 at 2:57pm |
That's why they have people smarter than me. If I did it it would look like a coiled snake taking a wizz!
LouSWPA
Posted: 04 Jan 2026 at 1:50pm |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90835 |
Posted: 04 Jan 2026 at 1:10pm |
around here there use to be a couple diesel powered pumps ... but any more they drop a 480v line to a base where the pump / electric motor and control panel set..
Edited by steve(ill) - 04 Jan 2026 at 1:11pm |
LouSWPA
Posted: 04 Jan 2026 at 12:49pm |
those irrigation systems that look like TV antenna towers laying on their sides, in sections supported by tandem wheel assemblies between sections, and tethered to a center well, or plumbing outlet.....how are they powered, and how is each section controlled speed wise, so that the system rotates around the center in a straight line?
