Hitch Descent Rate Valve
Clayfoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clayfoot Quote  Post ReplyReply Direct Link To This Post Topic: Hitch Descent Rate Valve
    Posted: 03 Jan 2026 at 5:30pm
My early D14 lacks the valve that adjusts the hitch descent speed, and since the wife will be driving it for the first time this spring with a mechanical transplanter and me in the back, I'd like to plumb something in the hydraulic line that accomplishes the same result and prevents the wife from dropping me and the transplanter hard. Are these just needle valves/flow control valves? Would it really matter where I'm the line I plumb it in (in thinking at the rest end instead of under the gas tank)? Anyone have a good picture of a factory valve? Thanks in advance!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 6:14pm
Why couldn't you put a regular 1/4 turn valve in the line and adjust it to a setting where the hydraulics work at the speed you want?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 6:35pm
There is not a "rate-of-drop" valve for a D-14 tractor from Allis-Chalmers. There is such a thing as a "one-way hydraulic flow control valve" that has a speed/flow control knob on it for less than $30 bucks. Use Google to find one. Place it at the rear to the left of the seat  between the steel tube elbow and remote coupler manifold. One way it restricts flow and the other way is free flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clayfoot Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 10:48am
That's exactly what I was hoping to hear. I'll be adding that in sooner rather than later and doing my hydraulic build in to of that. Thank you gents!
This page was generated in 0.355 seconds.
