7050 tach
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: 7050 tach
    Posted: 17 Nov 2010 at 5:57pm
Trying to figure out how to get the tach working on my 7050. Does it run off the alt, if so I have changed the alt to a chevy alt. The old one did have an extra wire hook-up on the rear but nothing was hooked to it. The tach hasn't worked since I have owned the tractor. I can't find anything in the shop manual on it.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 6:06pm
The tach does work off the alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 6:18pm
The old alt was a delco and had 3 spade terminals and a stud terminal. The alt I put on it was a delco but it only had 2 spade terminals and a stud terminal. The shop manual does not show any wiring diagrams and the only delco alt it shows is the one that is on the tractor now. Does anyone have a wiring diagram for this tractor? And maybe know where I can buy a rebuild kit for my old alt.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 9:58am
the wiring diagram is in the operators manual.   The correct alternator has two spades, one large stud and one small stud with no threads, the small stud with no threads is the tach pickup termainl,  the tach counts the sine waves off one terminal on the rectifier bridge.   There should be a small brown wire coming out of the harness with a terminal and black round insulator that pushes onto the small stud.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 5:12pm
Does anyone know where to get a working tach for a 7050?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 10:27am
My Delco has a third spade terminal in front of the 2 standard spade terminals. Yhis like is shown in the service manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 10:45am
You may check AGCO , they had a new one for a 6060 AC for $205 new ; wasnt bad I thought , a 7050 is prolly the same tach ;  Auto Value parts had a new alt. for $65 , had to swap pulleys worked great
