1952 CA
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: 1952 CA
    Posted: 30 Dec 2025 at 9:57pm
I started working on a CA I dragged home last summer - engine was loose, but missing distributor, nasty carb and gas tank, all tires shot, etc. Definitely a project with a lot of unknowns. This '52 that ran and had great rear tires came up at a local auction. I test drove it and figured if I could buy it for the price of new tires it was a no-brainer and here I am. The hand clutch seems to work and I didn't have any rear weights yet.
The float stuck so badly when I tried to start it to load it on my trailer that it wouldn't start. It dumped gas everywhere. Winched it on and did get it started again at home. It'll need at least a carb rebuild, fluids, and some other TLC. The starter makes an awful clashing noise sometimes... maybe the pinion doesn't always fully engage so that needs looked into as well. I'm looking forward to setting up a cultivator and building a mounted planter to do 15" rows. I might have to put a WFE on it for that.
One thing I was not sure about: when I let the clutch pedal out in neutral, the engine lugs down a little and the tractor drives forward an inch or two, then acts like it should in neutral. Do I have a bearing going out somewhere in the trans, or something else? My other tractors don't do this even with cold oil, but I haven't driven a CA before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 10:34pm
youi may have oil on the clutch plates and its dragging a little when put to neutral... When you take the starter out, get a weed sprayer full of laundry soap and water.. soak the clutch and throwout good... let it set and flush with a garden hose...
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 11:14pm
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 11:16pm
Serial number of my CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 11:38pm
What would cause it to want to move forward when in neutral though - the transmission gears shouldn't be engaged whether or not the engine clutch has rust or oil on it and is dragging, correct?
For example, I start the tractor in neutral with the clutch pedal in, then let off the clutch pedal after say 5-10 seconds, and it inches forward a tad and lugs the engine down slightly. I have not touched the gearshift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 11:50pm
So the rest of the forum isn't confused, ha - we had a PM conversation and it turns out we have CAs that are consecutive serial numbers. This tractor is CA17716.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 7:37am
your right john.. when in neutral it should not try to move.. I was thinking with the clutch pushed IN while in gear..... When the clutch is engaged and trans is in neutral, the TOP SHAFT is spinning, but should not have any gears engaged..  Maybe slop or bad detent in the shift lever ??  Dont see how a TRANS bad bearing would do it..... does the PTO work OK without noise ? ... does having the PTO engaged have any effect of the "try to move" ?
what im wondering is if there is a problem with a bearing or ?? in the PTO ...the lever should be disengagning it from the spinning top shaft.
Edited by steve(ill) - 31 Dec 2025 at 7:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 8:19am
What kinda lube is in it? I'd say it's just drag from gears on shafts trying to turn pinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 11:29am
That is a good point. I checked the dipstick and it smells like gear oil. Gotta change that out to the right fluid and see if it makes a difference. Still seems like it shouldn't go forward as strongly as it does even if it's due to thick heavy oil.
Other Steve - will check on the PTO, hydraulic, etc. operation after I get the carb cleaned up.
I would have thought if the shifter/forks/etc. were worn or not in the right spot I'd more likely get some grinding... but maybe not. Maybe it's just applying a little bit of pressure on something, then with the thick oil it actually transmits enough power to move a bit?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 11:48am
If it hasn't been run in awhile probably the drive shaft inside the flywheel is a little rusty
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 2:24pm
That was my first thought as well; cold, sticky 90 wt can transfer a fair amount of viscous drag motion. The design of the CA transmission has the countershaft right down there in the oil and directly connected to the pinion rather than having the power flow back up to the mainshaft like a 'normal' transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 3:17pm
It definitely has what smells like gear oil in the rear end. I will be draining that out. The carb is off and I'm starting to go through it. I don't think it will need much other than needle/seat and possibly realigning the floats and setting height.
With the engine off, I messed around with the PTO and belt pulley shaft.
1. The belt pulley shaft spins freely no matter what. Turning the PTO shaft by hand does not turn the belt pulley shaft. Looking at the exploded parts view it looks like the belt pulley and PTO shaft should always turn together just like on my Bs and Cs. I presume some gear teeth are stripped or something worse in the belt pulley shaft.
2. Trans in neutral, clutch pedal held down, and PTO disengaged (again, ENGINE OFF) - I can freely turn the PTO shaft with my hand. Nothing else turns. That seems good other than the belt pulley isn't turning like mentioned above.
3. Trans in neutral, clutch pedal held down, but PTO lever engaged (engine off) - when hand turning the PTO shaft there is more drag as you would expect, since you're turning things in front of the PTO shaft now, but the rear wheels rotate slightly. They are clearly not meshed completely in but the wheels will sort of surge slightly, almost feeling like the hand clutch being disengaged on a WD/WD45 in cold oil and still creeping a little from the drag, if that makes sense.
I think I'll be pulling the PTO/BP/hyd pump housing and taking a look inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 6:26pm
Yup. The CA has constant-mesh gears and you do not have a lot of leverage turning the PTO by hand with all of those gears swimming in that cold gear oil.
I am curious as to what you find inside because the belt pulley most certainly should be geared to the PTO shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 7:56pm
I rebuild Starters if interested. Looks like you scored a nice unit there!
Steve@B&B
Post Options Post Options   Thanks (1) Thanks(1)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 11:42pm
Got the carb off and the starter out. The carb had definitely had some gas dry out in it. The float was half full of gas. I think the threads for the main jet plug/adjustment needle assembly are trashed... they look stripped and there was a bunch of thread tape crammed in there that ended up everywhere. It's interesting that this carb has a main jet adjustment needle. Per the parts catalog and my other CA it should have a plug. I may need to make sure all the jets are sized properly if parts were getting swapped around. The main jet itself had no gasket on it when I removed it. I think someone probably cleaned this up for the auction just enough to get it running after it sat in the guy's collection for however long. Worst case I should have another carb bowl with good threads for the main jet plug/adjustment.
The starter pinion looks great. The ring gear... not so much. I am actually wondering if this tractor was never converted to 12V and someone slapped a new 12V battery in it before the auction. Will need to dig into the electrical more later to see if that's why the starter is slamming it so hard, and replace that ring gear or stick with hand cranking for a while.
I drained some very thick looking oil out of the trans/rear end. I did not get any chunks or pieces of metal though. The magnetic drain plug in the PTO/hyd pump housing had filings on it about in line with what I've seen on my WD/WD45s. If I have time tomorrow I'll pull more apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2026 at 9:04am
most tractors converted to 12v just had a battery change.. They are still using the original  6v starter and ring gears... I have several that way..
Gear lube in not your friend in the transmission / bevel gear / hydraulic system..
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2026 at 11:18pm
I got the PTO/BP/Hyd housing off today.
The sliding drive gear on the main shaft has experienced some trauma - maybe just from engaging the PTO with the clutch still engaged.
The casting is cracked around the rear bearing for the main shaft. I'm guessing a chunk of something wedged between the gear and the casting. I also wonder if the bearing race is cracked... Didn't notice that earlier, but looking at the picture it sure looks like it. I may have to tear this down.
Okay, the moment you've been waiting for, Les... The reason for the belt pulley shaft not spinning. I struggled to get this not so great picture, but the gear teeth for to drive the BP on the big double gear are gone... Someone intentionally ground them all off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2026 at 11:22pm
I can only figure that someone didn't like that shaft spinning when they had the PTO/hydraulics engaged, or more likely they trashed it somehow and went in and cleaned what remained of the teeth off. I suppose a belly mower hitting something solid could maybe do damage to those gear teeth? You'd hope a belt would slip, but that's all I can figure. There is no pulley on the shaft so maybe someone had a belly mower and v-belt pulley on there once upon a time. There was a C at the same auction that did have a v-belt mower pulley on that shaft.
I plan on planting and cultivating with this tractor so the belt pulley doesn't matter to me. I might do some PTO work with it eventually since I do have a sickle mower for it. I definitely need the hydraulic pump to work. I am tempted to replace whatever bearings are needed, clean up any high spots on the damaged gear teeth, and put it back together. My other option would be to steal parts out of one of my other 3 CAs (all currently non-running).
I am going to pull the side cover off the transmission next. Turning the mainshaft by hand still causes the wheels to move more than I think it should even with the gear oil drained.
Worst case I got some good rear tires and rims out of this!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2026 at 6:18am
Okay, the moment you've been waiting for, Les... The reason for the belt pulley shaft not spinning. I struggled to get this not so great picture, but the gear teeth for to drive the BP on the big double gear are gone... Someone intentionally ground them all off...
Whee! Reckon that will do it fer sure Big smileTongueLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2026 at 9:05am
DANG... old Bettsy has had a Hard Life !!  No way to treat a tractor !
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2026 at 11:18pm
No obvious nasty surprises inside the transmission tonight, at least at first glance. The wind picked up and my fingers got cold so I called it a night. Hopefully you guys are right and the thick gear oil is just causing things to stick together a bit. I'll try to make sure when it warms back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 11:28pm
Taking the PTO/hyd/belt pulley housing apart to replace bearings is going to be fun. I am wondering if the key for that driven gear got tweaked whenever whatever disaster happened. Haven't tried heat yet so that will be next to try to get the gear pressed off of the PTO shaft.
The retaining rings for the bearings also have me stymied for now. One end appears to be cut at a back angle to not give you any purchase, and both rings are like this for the two different bearings so it seems to have been by design. What's everyone's favorite trick for getting these out? I can try driving a pick or maybe a small chisel under the one in my picture, but the lower bearing snap ring is pretty beefy. I prefer the newer-style ones that have more of a gap/ledge to pry under with a pry bar or screwdriver.
The chunk out of the casting is just a small piece I plan on removing so it doesn't come loose later. I don't think it's big enough to hurt anything by being missing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 12:25pm
There were enough parts not available from my dealer, and that PTO driven gear did not want to come off, so I am changing plans in the interest of preserving things and saving some time. I will just clean this up and slap it back together.
There had been a lot of end play in the PTO shaft before I took it apart, but it had a good stack of shims under the end cap. With all of the shims gone I was able to take all the play out, so I can set it to somewhere in between and get it in spec. The bearings must not be that worn out so I am going to hope they last for a few more decades.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 12:45pm
Wish you were closer to Ohio, I have a transission laying in my shed that I took out of my CA it was jumping out of 3rd gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 7:16pm
John,
You are into this CA. Nice investigative work. After this many years and maybe abuse and misuse also, there can be many things that are bent, broken, worn or missing.
I did not take mine down that far. Your doing good!
 Chris and Cheryl
This page was generated in 0.244 seconds.
