Park brake
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Park brake
    Posted: 14 hours 32 minutes ago at 7:50pm
Is it possible to put in a separate lever for the park brake on an 8000 series powershift? It's a pain to have to shift the range lever to neutral and the into park and then back again. Especially when stopping to open and close a gate before the cows get through. Obviously would still shift the range lever into neutral for stationary work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 10 minutes ago at 8:12pm
It's a park LOCK, not a brake. And no, you can't have two levers. If you saw the way it was under the cab floor you would understand better. Maybe you need a couple of new cables to make shifting easier ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 12 minutes ago at 9:10pm
I can't comprehend the trouble you think it is to "park" an 8000 PS. Two levers..clunk,clunk and you're there.
This page was generated in 0.043 seconds.
