Machining allowances for flywheel on 160
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: Machining allowances for flywheel on 160
    Posted: 17 Nov 2010 at 1:56pm
Hello,
I have the clutch apart on our 160 and it looks like we'll have to resurface the flywheel and intermediate pressure plate before we replace the discs. I have the I&T shop manual but it doesn't list any of the machining allowances so I'm unsure how much I will be able to take off.
The flywheel also has cracks on the surface, I will take a picture and post it soon but was wondering if this is usual and something that can be taken off by resurfacing or if it may be a more serious problem, the cracks are all small and do not appear to be deep at all.
Also I see that the manual references disc lining kits, I have not called the Agco dealer yet so I'm unsure if the kit is still available but was wondering what is involved in relining the discs and whether or not it makes sense to do this myself or have it jobbed out.
Thanks,
Erik
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 2:25pm
Heat cracks, or "checks" are pretty common on just about any cast iron flywheel. I can't say how much you could remove to resurface, but on my D17D flywheel, they took .012 off to clean it up. They also took .012 off where the pressure plate mounts to keep the distance from the friction area to the plate the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 2:34pm
Depth mic from the pressure plate mounting surface to an unworn area of the clutch driving surface. Keep that dimension after machining. Whatever you take off the driving surface you have to take off the pressure plate mount surface. Heat cracks are pretty common.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 3:23pm
Yes, I am aware that the flywheel needs to be matched machined. What I'm looking for is the minimum allowable size (thickness) for the flywheel. I know when I did the clutch on our 180 there was a size range that the flywheel had to kept within, a range of about .032 IIRC, I need to know if the 160 has a similar range and what the minimum allowable size is.
Thanks,
Erik
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 6:58am
Thanks,
Erik
You may have checked already but it may be stamped on the flywheel somewhere.
Edited by TexasAllis - 18 Nov 2010 at 6:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 7:04am
Well guys I couldn't find a spec anywhere so I decided to take my chances and remove .010"
I think it will work out fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 11:29am
I called our local AGCO dealer for some prices and it looks like they can get me the PTO clutch disk and the transmission clutch disk for a little over $100 each. I was also told that the lining kits are NLA so unless someone here knows otherwise it looks like that option is out and honestly seeing how the disks are pretty reasonably priced it doesn't matter one way or another to me.
Now I'm wondering if the pressure plate can be resurfaced like the flywheel or better yet if it needs to be? It is glazed like the flywheel was and is also worn into the shape of the disk, I think this may be a problem when I install the new disk but am unsure if the pressure plate can be re-machined and shimmed somehow or if I will have to live with it the way it is.
Thanks,
Erik
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 11:34am
I always have a pressure plate resurfaced when doing a clutch job and usually the springs replaced, as there is a lot of heat created in a clutch, and heat+age=weak springs.  Check the yellow pages for a good clutch shop.  They can usually reline your clutch, rebuild the pressure plate, and have you good to go in a few days.  The local clutch shop is all I use any more.  It's probably not saving me a ton of money, if any at all, but I know I am getting a good product and have someone to go to who knows something about it if I run into any problems.  If you can't find a place in your yellow pages, call a couple garages up and ask them if they use a clutch shop.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 11:35am
Rebuilder skim or grid that surface also on plate, but springs and fingers may have to be brought back into spec as far as height and pressure.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 12:45pm
Hurst
Thanks for reminding me about the springs, I'll make sure I add those to my parts order as the last thing I need is for springs to fail a few hundred hours after I put everything back together.
I'll need to do some more looking at this clutch to see how I can compensate for the change in thickness when I resurface the pressure plate. I believe that there are stacks of shims that I can modify to make the adjustment but I'll check to make sure before I touch the pressure plate.
Thanks,
Erik
