H3 Starter
Pgriswd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Topic: H3 Starter
    Posted: 28 Dec 2025 at 5:59pm
I have a 1961 H3 and it has broken the nose off the starter twice. Does any know of a problem with this and what I can do about it?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 6:03pm
A bad/worn out ring gear on the flywheel, OR ignition timing set too far advanced, OR BOTH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 6:30pm
Thanks dr Allis
Will check out both
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 9:17am
The mechanical advance mechanism inside the distributor can cause the ignition to be too far advanced during starting if the advance mechanism is sticky due to corrosion and/or worn parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 9:34am
My 715-B TLB with Perkins engine has broken the nose cone of 3 starters over last 5 years . Seems starter drive was not moving forward far enough to fully engage ring gear -putting strain on outboard bushing in nosecone of starter .
 Worn bushings in starter can also allow movement to misalign armature .
Just bought a import starter (NEW) for less than cost of rebuilding the Delco starter again.
Edited by Coke-in-MN - 29 Dec 2025 at 9:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 9:46am
Thanks Les and Coke.   I checked the ring gear DR Allis recommended and seems fine. I think I have a timing issue and will work on that next
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 10:44am
Things that I take for granted and fail to express. When setting the ignition timing with a timing light, your goal is F-25 or FIRE or 25 degrees BTDC at full throttle. One should always idle down to 400 RPM (after getting timing set) to check the centrifugal advances operation. At very slow idle it should be at or very near TDC. This verifies that the advance is working correctly.  Also, the ring gear might look just fine where you looked at it. Every engine stops in one of two places. So, there will be two places of wear, 180 degrees from each other. The rest of the ring gear can and will look very good, but may be very bad in these two suspect places. Don't be deceived until you roll in completely around and look at all of the ring gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2026 at 12:40pm
Got and thanks. I will get on it a couple of weeks and let all know.
This page was generated in 0.219 seconds.
