Off color Minneapolis Moline starter
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: Off color Minneapolis Moline starter
    Posted: 28 Dec 2025 at 4:18pm
So I recently bought a UB diesel,been wanting one for over 30 years. Previous owner always pop started it after the battery that was in it when he purchased it went dead(15 years ago). I hooked up a battery and the starter would barely spin the engine over then just gave up. This is an obsolete starter (Delco Remy) model #1109236. I'm having zero luck finding brushes, starter switch or any parts at all for it. Can anyone here help me? I have located a used unit at All States Tractor Parts but would like to rebuild mine if possible
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 4:42pm
surprised an old time starter rebuild shop like lincoln way in dixon IL can't fix it.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 5:45pm
Call Steve at B&B Custom Circuits.  He might see this he often posts here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 5:57pm
they might be able to. Im only familiar with a couple shops over this way anymore. One in Maquoketa and he rubbed me the wrong way the last time I used him and then Gillespie down in Laclaire, planned on giving him a call tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 2:34pm
The model number 1113605 corresponds to a Delco Remy SD-35MT starter motor. This part number is now obsolete but has modern equivalents.
< jsuid="do2u1e_e" ="0" -amic="true" -icl-uuid="c720a461-26bf-4f62-b5b4-e947936ed50a" aria-label="View related s" ="rBl3me" js="click:&do2u1e_c|S9kKve;mouseenter:&do2u1e_c|sbHm2b;mouseleave:&do2u1e_c|Tx5Rb" -wiz-attrbind="=do2u1e_c/C5gNJc;=do2u1e_c/UpSNec;" -ved="2ahUKEwj_vOG80uORAxXUN94AHb8gAX0Qye0OegQIARAB" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">
Specifications for Delco Remy 1113605 Starter< jsuid="do2u1e_l" ="0" -amic="true" -icl-uuid="dcdc3606-4a73-41de-8904-237607a0b631" aria-label="View related s" ="rBl3me" js="click:&do2u1e_j|S9kKve;mouseenter:&do2u1e_j|sbHm2b;mouseleave:&do2u1e_j|Tx5Rb" -wiz-attrbind="=do2u1e_j/C5gNJc;=do2u1e_j/UpSNec;" -ved="2ahUKEwj_vOG80uORAxXUN94AHb8gAX0Qye0OegQIAhAA" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">
  • Part Type: Starter Motor
  • Model Family: SD-35MT
  • Voltage: Typically 12 Volts, but this specific number is part of a series that included different voltages.
  • Status: Obsolete
  • Type: New (at time of original release/listing)
  • Over Crank Protection (OCP): No < jsuid="do2u1e_17" ="0" -amic="true" -icl-uuid="01342c92-cdb2-4687-a4bd-08dce3415a96" aria-label="View related s" ="rBl3me" js="click:&do2u1e_15|S9kKve;mouseenter:&do2u1e_15|sbHm2b;mouseleave:&do2u1e_15|Tx5Rb" -wiz-attrbind="=do2u1e_15/C5gNJc;=do2u1e_15/UpSNec;" -ved="2ahUKEwj_vOG80uORAxXUN94AHb8gAX0Qye0OegQIAxAG" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">
For information on current replacement models, you can use the part finder tool on the official Delco Remy website to search by vehicle application or cross-reference the original part number.
Part Number
1109236
Status
Obsolete
Superseded By
1113605Obsolete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 2:38pm
35 MT is the new series for starter , it might be also replacement of truck or other heavy equipment .
It may now have a solonoid pull in switch rather than mechanical link
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 2:39pm
Part No. 1113656 — SD-35MT New Starter
Obsolete
Specifications
Part Number
1113656
Status
Obsolete
Superseded By
1993762Obsolete
1993881Obsolete
10461225Active
Model
SD-35MT
Type
New Starter
System Voltage
12
Mounting Type
SAE 1
Pinion Teeth
10
Pinion Pitch
8/10
Solenoid Position
060
Rotation
CW
Polarity
Grounded
No
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 7:45pm
I offer rebuilding services if interested. I can probably rebuid it for you.
Steve@B&B
customcircuits@gmail.com
