Model C carb
Kddrck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kddrck Quote  Post ReplyReply Direct Link To This Post Topic: Model C carb
    Posted: 28 Dec 2025 at 12:23pm
Friends:
I am having difficulty with a marvel schrabler carb. I’ve rebuilt it but it still seems to be flooding out the tractor. I’m beginning to think the load jets are too big.
Although I’m not going to claim to be an expert, I’m a pretty decent mechanic. I’ve rebuilt this entire tractor as I have several others. I just cannot seem to find out what the issue is with the carb
Is there anyone who specializes in rebuilding carbs on this forum?
Or does anyone have a carb in good condition that they will sell. Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 12:32pm
There are many that rebuild carburetors, however those M-S and Zenith tractor carburetors are so stone stupid that is you thoroughly clean everything  they work unless you set the float too high. There are some very small passages that plug easily.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 1:05pm
boil the float and make sure it does not hiss,   set the bowl level and carfuly fillit with gas and make sure gas does not come out of a crack in the bowl or the nozzle gasket,  i have seen several marvals that were cracked in the bottom  i am sure they had water and froze
This page was generated in 0.154 seconds.
