7040 oil transfer |
Zulawski200
Topic: 7040 oil transferPosted: 27 Dec 2025 at 1:19pm |
I am working on a 7040 that is transferring oil from transmission to rear end. I have replaced the pump drive seal and the seal between the pumps. I have replaced the the pumps from a different tractor and still transferring. The door on the filter housing is opening 8mm. It will go about 3 miles before all the oil is in the rear end. I have the lines off the steering pump and transmission full of diesel and no leaks coming out of steering pump when sitting.
DrAllis
Posted: 27 Dec 2025 at 3:51pm |
Lots of questions. It came to you doing this, correct ?? And how long has it been doing this??? I assume not since 1975 ?? Are you using genuine AGCO hydraulic filters (2) ?? I question whether any of the hydraulic lines/hoses are crossed ?? If it does the transfer in 8 minutes while roading it, does the same thing happen when sitting still at full throttle for 8 minutes ?? That would be nice to know. The shaft seal between the trans (gerotor) pump and the steering gear pump must be installed with the shaft splines wrapped with ONE layer of black electrical tape in a barber pole fashion. When oiled, this tape protects the seals rubber lip from being cut when sliding it onto the shaft. Both pumps must have good bushings and be in overall good condition. That seal has been installed backwards before and I think you should consider doing that. So, spring towards the rear. An 8 minute transfer sounds suspicious to me. I had a 7080 some 45 years ago that went the other way (rear to front) when reading and the top PTO shaft seal was in backwards (by some other dealership).
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3631 |
Posted: 27 Dec 2025 at 5:25pm |
I vote with Doc on the hyd hoses crossed. We have see seals blown and it takes several hours to pump the almost 10 gallons you are talking about. We have seen 2 units in the last 2 years that have the cooler hoses crossed and thus pumping at full flow the tranny to the hyd rear side.
BillinAlberta
Joined: 12 Sep 2009 Location: Saskatchewan Points: 362 |
Posted: 27 Dec 2025 at 7:13pm |
I know on my 7020 gas passer I crossed the hoses when the new engine went in.Bless you Doctor for getting me to check. Problem solved.
Zulawski200
Posted: 28 Dec 2025 at 9:46am |
It came to me with the oil transfer. I believe this guy purchased the tractor and it had this problem. A different shop put the seal between the pumps in 2 times and they gave up. The seal was cut when I first got the tractor. I ran it half throttle for 8 hours no oil transfer. Drive it down the road and all the oil will transfer. After it goes down the road then refilling the transmission it will transfer sitting still. I pulled the suction line off pump and let stand and some oil was coming out. I replaced the seal filled with oil let stand 2 days no leak. Drove it 2 miles to get a load of hay and transfed all the oil halfway home. Drained the oil filled tranny with diesel and with suction line off steering pump and nothing leaks out.The pumps and bushing look good. I changed out pumps thinking it might have a hair line Crack somewhere but new pump dose the same.
DrAllis
Posted: 28 Dec 2025 at 11:01am |
You ran it 8 hrs at half-throttle with no transfer. I assume this was sitting still ?? I would run it at full throttle for 10 or 15 minutes or less also sitting still and see what you've got. We have to keep consistent with the testing. I also assume going down the road for 10 or 15 minutes was at full throttle?? and this is when oil transfer did occur. You didn't respond to the AGCO filters question. I'm telling you, this is very important, especially on that left hand filter. An 8 mm door opening gap doesn't sound large enough to me. Is the push bar bent at all? they can be. "Short" filters have always been a big deal when they aren't AGCO filters. Also, after-market filters are sometimes too "fine" in their filtering and this also is bad as it causes pumps to have to work harder to get oil thru them. Does the power steering ever act or sound like it is cavitating? or struggling to get oil ?? IS THE SCREEN INSTALLED ON THE INSIDE OF THE LEFT FILTER ?? From being hundreds of miles away, I'm all in for a new left hand ACGO filter (and screen) and a door that opens 13 mm or more and a gerotor pump shaft seal installed backwards with the spring towards the gerotor pump. BUT, test it all FULL throttle sitting still first !!! if it transfers at full throttle and not at half-throttle there is (I believe) a high suction issue which pulls the oil thru the gerotor pumps shaft seal, but only at full throttle. Makes sense to me.
Edited by DrAllis - 28 Dec 2025 at 5:41pm |
