ca hand clutch
rilenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Topic: ca hand clutch
    Posted: 20 Dec 2025 at 7:05am
Morning my I believe my question is to Les Kerf. Did you ever move the ca hand clutch to the other side and was it difficult.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2025 at 2:16pm
This project is still a work in progress which has been delayed due to more pressing issues. We have both final drives removed from the tractor and most of the parts have been collected (brake drum & bands, clutch disc, seals, etc.). As time permits we will begin re-assembling.
We have not yet swapped the 'adapters' on the transmission case from side to side but it doesn't look difficult.
The goal is to have it running before springtime Wink
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2025 at 6:58am
Dennis A. Il. has a video on his You Tube channel about the swap, I think. Not sure what the name of his channel is.
Cernunnos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2025 at 9:12am
Dennis'  YT channel is called Antique Allis.  Very informative, detailed and helpful information.  I hope he creates some more content.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2025 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2025 at 9:44am
That is a great video and one i used when i removed my hand clutch. But my real question is to change lever and clutch to left side other then lever, clutch, axle is there something in the pumkin parts that needs to be changed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2025 at 1:33pm
Never been around one but thought the clutch was all in the axle housing so differential plays no role.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2025 at 6:37am
well I'll be attempting this switch this spring after all the snow plowing. With the help of my books and this great site we'll see how to goes.
This page was generated in 0.277 seconds.
