D 17 electronic ignition
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: D 17 electronic ignition
    Posted: 17 Nov 2010 at 8:09am
 Does anyone know if I can get an electronic ignition kit for a positive ground sytem? I ordered a kit for my D 17 from NAPA, and the instructions say that it is for a 12 volt, negative ground system, and my 17 is positive ground. Thanks for any help,  Darrel
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 8:15am
Darrel  !!  I just checked my  catalog,  12 -  Neg  only.    Tony
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 8:22am
If you're set on having the electronic system I would consider changing your traxctor to a Neg ground system; I can't imagine it would be too big a problem.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 8:30am
I got a pos grd Petronix EI from Steve(NJ) for my D15Series II a few years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 10:10am
Just swap the battery cables around and polarize the generator. That's all it takes to make the polarity switch. I bought the matching Flamethrower coil to go with both of my gas tractors just be sure I had the correct coil. They are sensitive to the coil primary resistance. If I remember correctly, the 12V unit needs to have at least 3 ohms of primary circuit resistance. If the resistance is lower, the coil draws too much current and it burns up the module. When I bought mine, I figured if I used their coil and had a problem, they would be more likely to cover it without problems. The CA has had one on it for a couple years now. The Oliver 60 has had one for about as long and has been on several tractor rides where it ran all day. No problems.
I'll add that I also opened the plug gaps to .045. Big difference in ease of starting and smooth running.
Edited by Brian Jasper co. Ia - 17 Nov 2010 at 10:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 10:34am
You do have to swap the wires on the + (Ign) and - (Dist) terminals on the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 3:30pm
We have 12V PG in stock. Just shoot me the Distributor number. Drop us a line if interested.....
Steve@B&B
