6080 turbo
BenHD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenHD Quote  Post ReplyReply Direct Link To This Post Topic: 6080 turbo
    Posted: 15 Dec 2025 at 9:44pm
have any of you guys ever changed out the turbo on a 6000 series to one that will spool up faster at lower rpm?
might just be me but i think these tractors do not lugging very well at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 10:36pm
Have you owned the tractor long?? That's kind of the way they are under 1700 RPM. They are only 200 cubic inches. You might check the injection pump timing and consider setting it at 16 degrees BTDC instead of 18 degrees BTDC.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 8:01am
also check boost pressure, it may have a boost leak, plug fallen out, blown intake hose or gasket, or simply a bad turbo.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 8:08am
This is a very small turbo for 200 cubic inch and builds up to nearly 30 #  Cant do much better than that for around 100 Hp - suggest checking the things Doc and Ed  stated. Also performance issued could be as simple as fuel restriction. One can unscrew the bleed screw at the back of the pump in the center of the 4 outlet lines at an idle and fuel should still come out w/o killing the engine. IF the engine dies there is probably a supply issue.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 2:40pm
Below 1500 rpm, they will fall on their face, but over 1500 you will not stop it.  No engine likes to be lugged, just open up the throttle more and you will be good.
Keep in mind, even though they were rated at 83 hp from the factory, most crank out more than that.  Mine dynos at 112 hp.  If you need more than that, buy a bigger tractor.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2025 at 8:35pm
Intercooler clean?
Had a 6080 go weak ends up cooler was plugged but as others said they don’t lug well just no cubes.
6080fwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2025 at 8:38am
The tractor is what it is!!!  I have seen so many tractors with a rod thru the block!
How does that happen?
BY LUGGING!!!!!!!!!!!!!!!!!!!!!!!
If your working at 75% power or more and the rpm rises more than 150 when u put the clutch in and stop you are likely overloading the tractor, use the next lower gear at the same power setting !!!!!
Most of these old girls are 40+ years old, dont torture them.
you want a tractor you can lug all day buy a versatile 855
or a white 2-135 or 2-155 with more cu inches but still overloading
never does any of them any favors......
I have never blown any tractor  in 30 years of farming.
i own 4 6080s and they are irreplaceable for the jobs they do year in and year out
and dont try carrying 2 round bales with a loader and expect the axle or spindles not to break!
merry christmas!
d19d d19lp 175d 190d 190gxt 190dxt 200 6080 7000 8010 9150 9190
