Allis Chalmers WD45 crank removal ?
Pointer Hollow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WD45 crank removal ?
    Posted: 15 Dec 2025 at 8:58pm
Well the tractor I bought off a member of this forum arrived on Thursday and I am already working on making it mine. He really made me a good deal and this machine is awesome!
I have someone welding up a bracket for the front to hang some suitcase weights and I am thinking about removing the piece circled in blue that the hand crank engages to.  I have the original handcrank still, but I am thinking having this mechanism is a moot point.  How hard is it to remove this piece?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pointer Hollow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 9:03pm
Here are some more pictures of my machine.  I had to wash all the road salt off from the ride to PA.  It wasn't easy in the cold weather.  I then brought it inside to start setting it up for our farm.  I decided to rub it down with some linseed oil.  It really brings the old paint up a little.  I will paint the engine to cover up the
 primer they put on when they rebuilt it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 9:27pm
Just whack it off and leave 1/2" sticking out. You want the hole plugged to keep dirt out.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 6:10am
It's actually kind of handy if you ever have to work on the distributor.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 9:37am
Also handy when doing valve adjustment.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 11:20am
Take the bolts and spring and pin out behind the bolster. It should slide out tbe front.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 11:53am
On mine with the 6 cylinder swap, it was removed and has cork plugs in the holes
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 12:16pm
I would do what Nathan said and save the parts. JMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 3:03pm
Out the front and plug the holes....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 3:38pm
If doing it that way, I would cut off or torch off the pin on the engine end, instead of driving it out and bending the shaft while laying on your back working overhead. remember a wide front hand crank shaft has that "knuckle" on the engine end, making its removal even harder.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 12:36pm
Filling the holes will not only keep out dirt, it will keep the mice out!
The P.O. had removed that shaft on my WD-45 and the mice got into it while it sat one Winter.
They completely filled the cavity with nesting materials. So much so that the gears were so jammed up it was impossible to steer it.
' took me an hour or more to fish out all the stuff with a hooked piece of wire.
My WD NF has a nice bolted on plate that would have made the job a lot easier.
Edited by Brian G. NY - 17 Dec 2025 at 12:39pm
This page was generated in 0.083 seconds.
