7040 air in fuel system
INAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Topic: 7040 air in fuel system
    Posted: 11 Dec 2025 at 3:01pm
7040 used about once a week or so to load round bales, today lost power lots of smoke, could see air bubbles in fuel filter. Turned off hand primed bled air cracked injector ran great 10-15 minutes and repeat. Pulled this 3 times but got hay loaded, shut down repeat everything fine for short time. Final time hand primer didn't seem to wanna prime, could this be bad and allowing air into system?? If not the cause, im at a loss. Any help? TIA
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 6:13pm
That’s where I would stert
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 6:14pm
sounds to me like a fuel flow restriction from the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 6:24pm
Early 7040's had a plastic fuel supply line from the fuel filter base rearwards to under the cab floor to on top of the main fuel tank. The engineers made the injection pump draw fuel up thru a standpipe. It was a bad idea and oftentimes caused problems like this. Their fix was to go with a larger (than the plastic line) diameter rubber hose from the fuel filter base down and under the tractors belly and tap into the main fuel tank via the cross over hose between the tanks. This bottom draw system was what was needed and all the way thru the mighty 8000 series, that is the way they were. So, if you have the standpipe system, now'd be a good time to just eliminate it and convert to a home made bottom draw design. If you currently have a bottom draw system, disconnect the rubber supply hose at the filter base and hold it down below the fuel tank bottom and see if it GUSHES fuel out the end. It should. If it doesn't, you have a blockage at the outlet of the tank. By the way, if the hand primer squirts fuel all over when you pump it, it's junk.
Edited by DrAllis - 11 Dec 2025 at 6:24pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 9:47pm
If it does have the gravity flow system,  then the hose from the tank should have an adapter and elbow at the filter base. They have been known to plug with debris at that area. May need nothing more than a fuel filter change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 9:51pm
New fuel filter about 6 weeks ago but haven't ruled it out. Tank about 3/4 fuel. Will continue to check lines thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 9:53pm
Runs perfect for an amount of time, you can literally watch air bubbles form in the filter until it smokes horrendously
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 10:15pm
I have a diesel tractor doing exactly that, I need to pull the tank and clean the gunk out; pulling the sediment bulb and poking a wire up through the wire was insufficient but it did make it able to drive it back to the shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 11:12pm
Check the flow from the disconnected hose FIRST. If OK, then move on to the filter base connections/base inlet being plugged. Then, the filter itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 8:51am
Just a quick note, the primer leaking when pumping it is not always an indication it will allow air intrusion, the end of the plunger blocks the hole to seal it off when it's held in the housing with the bail and screw. The rubber does get hard and brittle eventually though. Even a new plunger can leak a little fuel when pumping it, but still should seal up the system when bottomed.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 10:50am
One fellow ikniw has a 8050 that did that. Wound up getting a rubbervglove out of the tank. Another fellow had. 1566 that did that. It was a golf ball. That ball would get sucked iver the outlet and after it cut the fuel off it would roll off and the tractor would start right back up. I know niether one of those is your problem you hav similar symptoms. Could be something in the tank is getting sucked over the outlet and when flow stops it releases and it will start again after priming
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
This page was generated in 0.079 seconds.
