D 15 Series II engine question |
jpi72
Joined: 27 Jul 2019 Location: Hudson, Iowa Points: 49 |
Topic: D 15 Series II engine questionPosted: 10 Dec 2025 at 2:15pm |
I own an AC forklift with a D15 Series II (160 cu. in) engine. Cylinder 3 has zero compression currently. It happened quite suddenly. Does this engine have head problems? We are planning on taking the head off after Christmas.
Joel
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7630 |
Posted: 10 Dec 2025 at 2:39pm |
It's a stout engine with no known issues. Could be a stuck valve? You won't know until you open it up.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55224 |
Posted: 10 Dec 2025 at 3:26pm |
#'s 2 and 3 are closest to the upright muffler. Could be as easy as rust hanging a valve open...
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90645 |
Posted: 10 Dec 2025 at 3:50pm |
take the valve cover off and look at the valves now... then you can narrow down any work on the head ...
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 10 Dec 2025 at 5:31pm |
I have a D-15 II that I bought at the end of May 2025. It had a skip. When I did a compression check, #2 and #3 were down considerably on compression compared to #1 and #4. Here's what i found when I removed the head.
steve(ill)
Posted: 10 Dec 2025 at 5:41pm |
since #2 and #3 are 180 degrees apart, you would think if the head gasket was blown, youi would have zero compression on both cylinders ?? ... when one cylinder is on COMPRESSION, the exhaust valve is open on the other cylinder..
WF owner
Posted: 10 Dec 2025 at 5:57pm |
It was a while back, but I believe I had about 60 psi on 2 & 3 and close to 150 on 1 & 4.
WF owner
Posted: 10 Dec 2025 at 6:07pm |
Here is a link to my post about it.
edognight
Posted: 29 Jan 2026 at 8:04am |
I went thru this very recently, and on my 160, the valve seats, the parts recessed into the heads were gone on three cylinders! I did a compression test and one cyl was good, one was very low and two were zero. I sent everything to the machine shop, and very quickly the thing was up and running perfectly. there was zero damage to the piston tops.
I'd have to agree, this is a tough engine. What must have happened was the owner just took it to the bitter end, until it did not run at all. I am never again buying a machine with a tree growing thru it. |
steve(ill)
Posted: 29 Jan 2026 at 8:17am |
joel has not been back to this site since this post 45 days ago... Sure would be nice to know what he found ?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 29 Jan 2026 at 8:18am |
It's been my experience that things from down south have been beat to death worse than a rented mule.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8971 |
Posted: 29 Jan 2026 at 10:19am |
I had a great mentor who said the same
jpi72
Posted: 29 Jan 2026 at 8:27pm |
Yes, I am overdue for an update. We did get the valve spring reattached to the valve without removing the head. We had zero compression in that cylinder.
We took the head off of the engine. The valve was bent enough that it would not close properly. That accounted for the zero compression. The piston had a blemish where the valve had hit it. The cylinder wall had one small line in it that went up and down. My son and I decided the damage was not worth a complete tear down. So new gaskets and put it back together. it runs fine. We are guessing the engine is around 60 years old and now has some internal scars. Feel blessed that the damage was not worse. Thank again to all of the input. It is a real help when you are guessing what is wrong with the engine. Joel
Uncle Al
Joined: 22 Jul 2024 Location: Garrison ND Points: 8 |
Posted: 29 Jan 2026 at 10:16pm |
Reminds me of when we were racing an IMCA modified on a 3/8 mile dirt oval a few years ago. Leading the a main and the engine developed a bit of a flutter. Didn’t seem to be down on horsepower as we kept the lead. With two laps to go there was a caution flag and as soon as he got off the throttle one cylinder went dead. As luck would have it the caution lasted long enough that they called the race and paid us for the win. When we pulled the valve cover on the small block Chevy there was a broken valve spring and the creepers came out and dropped the valve. Bent the valve a bit and pushed it back up into the guide with a barely visible nick on the piston. We drove the valve out cleaned up the minor damage to the guide and put a new valve and spring and we ready to go again. Sometimes it is better to be lucky than good!
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1589 |
Posted: 30 Jan 2026 at 7:20pm |
Now that's the way to win a race! Lol!!!
