AC Forklift with D15 engine
jpi72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpi72 Quote  Post ReplyReply Direct Link To This Post Topic: AC Forklift with D15 engine
    Posted: 10 Dec 2025 at 2:10pm
I own what I believe is an AC 610 forklift.  It has a D15 series II engine (160 cu. in.)  Was engine noted to have head problems?  The third cylinder lost the keepers on the exhaust valve.  We got the valve reattached and replaced with new keepers.  Then to find out the that same cylinder has zero compression.  After Christmas we will remove the head.  Does anyone have experience with this problem?
Joel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 8:29am
If you dropped a valve I suspect you have a hole in a piston. How were you able to retrieve valve after loosing keepers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpi72 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 10:50am
The valve must have been supported by part of the combustion chamber beside the piston.  I am fearful we have piston issues.  We will know more when we lift the head.
Joel
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 10:57am
Probably a hole in the piston or a bent/broken valve, maybe both; either way the head needs to off if you intend to fix it.
You could blow air in through the spark plug hole with the piston at TDC (firing position) and listen for where the air leaks out. This really won't prove much other than verifying that you have a problem, which you already know Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2025 at 2:52pm
Blowing in air will tell if bad piston if air comes from crankcase breather
 If air comes from carb - bent or broken intake valve
 If air heard in exhaust - bad valve on that port .
If more than one - you have a big problem -
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 1:12pm
vaccumm test the head i am sure you have a bent valve stem
