7010 engine overhaul
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Topic: 7010 engine overhaul
    Posted: 03 Dec 2025 at 10:52am
My open station 7010 started dripping coolant out of the breather this summer and parked it after I noticed it.  I'm not sure when it started but it wasn't this way when I had the valve cover off late last winter and have only put less than 10 hours on it in the spring Have since dug into it and found a leak coming from between the number 6 sleeve and block.  It is tired and needs a freshening up anyway.  Wondering about what kit to use.  I did put an Absolute kit in my 190xt a few years ago and have been happy with it.  Seemed like a good kit and would probably go that way again.  I have also found a kit from Federal Power Products, wondering if anybody had any experience with this kit or not?  I am not interested in a Reliance kit.  Thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 3:51pm
Sounds like you need block work more than an engine kit. I would check sleeves for roundness and re ring if ok - you will have to do a close inspection to determine what is needed - you are going to have to spend the money sleeving the block bottom bores quite possibly and by all means re-bearing all.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 4:00pm
We rebuilt a 301 in our 200 January 2024. Used a Reliance kit from Agkits. Bought the gasket set from Agco. We were satisfied with the Reliance kit. Tractor starts and runs perfect. Gonna split an XT tomorrow for a rebuild. Plan to do it the same way. Sorry I couldn't be more helpful.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 6:01pm
For best results, remove the oil pan FIRST and pressurize the cooling system to 100% absitively determine where the leak(s) are coming from before you rip it all apart.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 7:39pm
I replaced my 7010 head because it had cracks around the injector sleeves. I used a 200 head because they didn’t have sleeved injectors. Could your leak be coming from the injector sleeves or head cracks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 8:53pm
No it's from the bottom between the sleeve and the block on number 6. I had allready pulled the pan, pressurized the system and had the block heater plugged in yesterday and had a pretty steady drip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 9:36pm
Uncle had to sleeve the bottom bores on a 7020. 301 known for electrolisis down low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 8:36am
So I am in the process of putting this thing together.  Got the sleeves in and main bearings in.  Got rods and head back from machine shop a couple days ago.  I did order new rod bolts and was assembling pistons to rods and putting new bearings etc. in rod.  When I went to put the new rod bolts in I am having difficulty getting them to thread into the rods and they also do not want to fit through the caps very well.  They will begin to thread in but then they get tight.  The rod bolts I ordered from agco, but I don't like the way they fit and will probably just reuse the old bolts.  Has anybody else had an issue with the rod bolts from agco.  I believe they are sourced from ARP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 9:26am
The ones for the 426 I have used have ARP stamped in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 10:06am
301 Rod bolts 74024583 have never been an issue. The 426 were the ones changed to ARP many decades ago by request of the AC service department.
The new bolts should thread in by hand if the old ones will - otherwise I would not use them - Somethings wrong. There were two rods on the 301 - the old ones had 6 point and the 12 point bolts will not interchange w/o machining the old style rods - the old bolts are NLA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 10:33am
Yep that's the part # of the bolts, but they will not thread in maybe more than a few turns and they get tight.  They will thread into a fine thread 3/8 nut just fine as will the old ones but not in the connecting rods.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 11:09am
hmmm,,, whatever ya do, I wouldn't re-use the old rod bolts.  maybe get a NEW tap and die and run the threads on the bolts and rods... look into newer rod style that fits the new bolts?.?.. yea, I know,, more $$$ to spend,, but I really hate to see you open a window in the block after ya done all this work..
or maybe contact ARP and see if they have a solution....
Edited by Michael V (NM) - 23 Jan 2026 at 11:09am
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 12:36pm
Do your old rod bolts thread into the rods like they should...or is there something wrong with the rods after they came back from the shop?
Matt Folkers
FOLKERS RESTORATION
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 1:57pm
I've had to chase the threads in the rods, and also de-burr the holes in the cap to make sure they turn free without binding, throwing off the torque.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 7:40pm
Old bolts go right in easy by hand and these are the new style rods which just got new pin bushings put in at the machine shop.
Edited by HagerAC - 23 Jan 2026 at 7:42pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 7:56pm
Not a Reliance kit.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2026 at 12:23am
Ran into that problem sometime back and saved this sheet...Dale
BcrazyTH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BcrazyTH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 2:20pm
Which brand of overhaul kit did you end up using? I recently discovered Absolute as an alternative to Reliance, unfortunately FPP doesn’t list a kit for the 190XT.
Ben (Eastern Washington)
WD45
190XT SIII
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 3:12pm
Do they list a kit for a 180 or 185 ?? same kit fits an XT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 8:35am
I ended up using an Absolute Kit which I also put in my 190xt.  I have really been happy with it in the xt and hopefully will be with this one as well.  As far as the rod bolts go, I did measure them with a Mic and they were definitely a little larger in diameter than the ones that were in there, i think it was like .004 larger.  I ended up putting the old ones back in, I really couldn't see why I should have to do a bunch of work to make the new bolts fit and thread in nice so they torque correctly.  I would have had to bore the holes slightly in the rod caps and also tap all the threads in the rods.  Same part number comes up for all the rod bolts in 190xt, 180-185 book only shows old style rod bolts.
Edited by HagerAC - 27 Jan 2026 at 8:42am
This page was generated in 0.107 seconds.
