185 power steering cylinder
Allis_Cooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Topic: 185 power steering cylinder
    Posted: 02 Dec 2025 at 9:36am
Anyone on here have any experience disassembling the power steering hydraulic cylinder on an AC 185? There does not appear to be a cap that screws off nor do I see any snap rings.
Wink Someone on this forum will know the secret, they always do.
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 10:13am
Tap head back inside enough to remove snap ring then pull out
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 1:12pm
Worked like a charm! You guys always know the answer.
The pressed in outer seal around the shaft was a bear to get out!
Installing seal kit  70255712-5 from DJS Tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 2:10pm
Before installing piston back into the barrel, wrap the new teflon piston seal with two wraps of paper and place a radiator hose clamp around the teflon seal and compress it. I'd wait overnite if it was mine and remove the clamp, grease/oil lightly and stick it slowly into the barrel. If you don't do this, chances are pretty good you will cut the new piston seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 5:10pm
Thanks for the advice on that.
When I took the piston off the tractor the spherical swivel joints on either end fell out in my hand and some of the joint housing cracked off. Unfortunately, the only replacement with the correct dimensions I've found so far are from A&W Tractor  Part Number: 244019V $136 each!!
If anyone knows of  another source please let me know. They seem to be .3/4" ID and 1 5/8" OD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 6:48pm
well....the right parts are always worth what they cost. Your experience may differ.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 5:29am
AGCO has 70244019v For 102.95
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 3:54pm
x2!  No ordinary cylinder will do the job.  Those swivel balls do get a lot of wear and tear over 40-50 years.  Yes, they are expensive, but you do need them.  Grit your teeth and pay the price.  Have done several of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 7:18pm
Just think of a company still offering parts for tractors last built in 1985 and changed hands multiple times. But cost does stink
