Coil spring bottoms out
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: Coil spring bottoms out
    Posted: 30 Nov 2025 at 12:31pm
Allis c coil spring with shock. I’m 210lbs and this spring bottoms out. What’s my solution?
Coil over shock absorber to gain more tension or is a newer coil spring stiffer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 9:54pm
A new shock/spring assembly will be better than what you have. That's what coil springs do over time......flatten out. If it has an slot adjustment, move it as far to the rear as possible.
Edited by DrAllis - 30 Nov 2025 at 10:07pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 6:00am
I put an old air shock on the seat of my 1941 Johnny Popper. I'm about 100 lb heavier than my grandson so we can adjust it to suit our needs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 2:49pm
Nurtisystem
Weight watchers
Olesra chips
Paleo
Pritkin
 The choices are endless LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 6:18pm
Funny good one. And yet I’m considered thin by coworkers at 6’2” . I’m going to try a small coil spring rated at 130lbs. just behind the fulcrum along with the original under seat before buying a new large coil spring and spring over shock. I’d prefer this if it works as my wife (120lbs) will use it to mow at times. Take out the small spring for her and vice versa.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 12:12pm
My grandfather was a 6'8, 330lb mountain, who saddle rode his percherons and carried and tossed two 90lb alfalfa bales in each hand <by the strings> like they were tennis balls, and pushed around Santa Gertrudis bulls like they were kittens. His tractors all had stiff springs. when i was a teen, I raked hay with his D17 wondering why the seat had no 'give'. I spent the day after standing on the rack, glad to have my rather sore posterior NOT in that seat...
Turns out, there simply wasn't enough load for the seat to respect my then-much-lesser gravitational attraction...
