D14 questions
Leadfeather View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadfeather Quote  Post ReplyReply Direct Link To This Post Topic: D14 questions
    Posted: 29 Nov 2025 at 9:26pm
I am considering purchasing a wide front d14 that seems pretty clean but I noticed it has 14-24 industrial tires on the rear. I was not aware this was a tire option in this size. Tire options are limited are there any options for buying wheels and tires from other equipment?I am looking to use this tractor for a preservation / pasture clipping and maybe some garden work. Is there any model specific problems i should look for.   Thanks in advance
Edited by Leadfeather - 29 Nov 2025 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 10:23pm
Standard "FARM" tires were 12 x 26 diameter.... I dont know about the D14, but many industrial tractors came with 14.9 x 24 tires ... we have that on a CASE backhoe.. Tires are readily available for 24 inch rims.... the 26 are more difficult to find.... you maybe lucked out !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 3:37am
Welcome to the site.Clap
As someone else said, 26" rims were factory.  Used rims/ tires from an older combine will work, but won't be PA rims... Other than the usual fluid leaks, check to see if it slips out of 3rd gear, when it crests a hill, and starts to go downhill...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadfeather Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 7:39am
How would these old tractors do for casual fall bushhogging with a 5-6 ft pull type shredder/bushog?
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 7:53am
Absolutely great! I use a model 160 brush hog trail type mower behind the d14 with no issues every year.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 8:04am
A pull type that has its own lift cylinder would do well behind it. The tractor has a single hydraulic coupler at the rear to plug into. That would be the preferred type mower versus 3 point lift if it has a aftermarket 3 point system on it. Then you would have to add several hundred pounds of weights on the front end to keep it on the ground. Is it 6 or 12v? If you know the serial number we can tell you what year it is. 1957-1958 were 6v, 1959-1960 were 12v. Power steering was also an option in 59-60. Neat tractor, I am going through mine now fixing a few things on a one owner tractor I bought last year. Replaced the brakes and seals in that area last winter. Good little utility tractor for what your planning to do with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2025 at 8:44am
re: 6 or 12  ?
The  one clue is whether there's a 'band' around the starter where the brushes are.
 if there's IS a band, it'll be 6 volt,
 NO band = 12 volt.
 At least that's what I learned from the 4 D-14 I've had.
