Pros and Cons of corn pickers |
Page 12> |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2295 |
Topic: Pros and Cons of corn pickersPosted: 28 Nov 2025 at 6:37pm |
Looking to purchase a 2 row mounted corn picker.
Ill be picking less than 5 acres each year.... My disire is to have a D17 gas tractor under a 190 model corn picker.... My second choice would be a D17 with New Idea mounted picker.... What is your thoughts fellas.... |
dkattau
Posted: 28 Nov 2025 at 8:01pm |
Storage of ear corn is a con if you’re not set up for it.
Macon Rounds
Posted: 28 Nov 2025 at 8:48pm |
That's not an issue...
DrAllis
Posted: 28 Nov 2025 at 9:24pm |
Pick your poison. There would be 10 times (or more) New Idea's to find used parts for. The Allis would have the benefit of stripper plates.
jvin248
Posted: 28 Nov 2025 at 9:30pm |
We had a New Idea mounted on an Oliver 880 when I was growing up. Later we had a self propelled Case combine, open station! "In the weeds" always sat the two row pull behind picker. Never knew why it was parked, and especially not used when the Oliver broke the fancy helical gear set first used on the 880 to cut trans whine. Homesteading or smaller farm I'd try to locate a pull behind picker. Easy to hitch and go. Mounted pickers are great for "opening a field up" in the outer rows. But those outer rows are eaten by deer and poor yield because of grass and trees. I'd plant a cover mix band around the field and use a pull behind picker. . |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5448 |
Posted: 28 Nov 2025 at 10:54pm |
Grew up on a single row New Idea picker. I admit the mounted 2 row pickers are neat but I can see where they would be quite noisy and dirty to run. Although compact compared to a pull type, the pull type are easier to work on and don’t tie up a tractor for a length of time. Most that were mounted, stayed on that tractor due to difficulty on mounting and unmounting. Wish dad had went to a 2 row picker but a single row kept us busy unloading a wagon one scoop at a time into the elevator to the corn crib. Good times…gravity wagons were to come years later lol.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8946 |
Posted: 29 Nov 2025 at 12:18am |
How about a Uni-Harvester? Neighbor had a 4 row unit.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1523 |
Posted: 29 Nov 2025 at 6:48am |
I pick 10 to 15 acres per year with an old style mounted ac picker over a wd 45. It never comes off. You will really put a work on the hand clutch if you get anything over 150 bu corn. Not as dirty and loud as some people say but it is my favorite thing to do so i may be prejudice. You have to plant wide(36 inch) rows if you plan on using a mounted picker. When i was a young man i picked corn with an ih 450 and a two row mounted 234 picker. Not a fan of the red paint but that machine was a beast!
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4264 |
Posted: 29 Nov 2025 at 7:57am |
In the world of mounted corn-pickers, the 234 is king! They are easy on/off too, especially if on a Fast-Hitch tractor. Don't think I've ever seen an Allis 170 or 190 in action.
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1046 |
Posted: 29 Nov 2025 at 8:55am |
If you only have 5 acres, a 1 row New Idea is all you need. Fairly cheap and parts are mostly available. But, if you want to suffocate in dust and dirt, then a 2-row mounted is what you need.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8387 |
Posted: 29 Nov 2025 at 10:40am |
There are definite pro’s and con’s to picking corn vs shelling(combining) corn.
Horsepower requirements for each can differ greatly. Storage of the harvested crop also differs. Labor required for ‘post harvest(storage)’ handling can be significant. |
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 581 |
Posted: 29 Nov 2025 at 10:53am |
Being old, I grew up in the era before shelling in the field. Shelling was done by a local guy with JD Sheller mounted on the truck chassis. He made the rounds, and it was a labor-intensive workday. Trucks were mostly just 2/2 1/2 ton with a combo grain-livestock bed. Occasionally a tandem with a bigger grain box. Even back then, fire was a hazard. Mostly from exhaust on sheller truck & husks everyone. Had one fire that I recall & it was quickly doused. Shellers were mostly JD with an occasional rare Moline. Those were the days.
jvin248
Posted: 29 Nov 2025 at 7:03pm |
I was surprised to see corn seed harvesting uses modern combines that pick ears. They store ears until the start of the year to shell, sort, clean, bag at the facility. I had assumed they shelled in the field like all the modern combines. Apparently the cob is a good seed performance enhancer. The other large modern ear picking I saw was at the Missouri Meersheim Corn Cob Pipe company. . |
DanWi
Posted: 29 Nov 2025 at 7:09pm |
No need to dry cob corn for storage if it reaches a reasonably level not sure what's recommended any more. Just a guess maybe 20% for cribbing. Cattle seem to like and do well with ground cob corn.
Gary (sw Wis.)
Silver Level Access
Joined: 12 Sep 2009 Location: S.W. Wis. Points: 222 |
Posted: 30 Nov 2025 at 7:56am |
I have and use a 190 picker on a WD. It work well if you can go slow enough or plant a low population. The rows are wide, 42 inches I believe but it pick 38s OK. The later I pick the better luck I have, dryer with less chaff and junk to go through. The biggest problem I have is the chaff getting though without plugging up. If you get a 190 picker and have a choice I would put a D17 under it.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2732 |
Posted: 30 Nov 2025 at 10:12am |
I would recommend a two-row New Idea pull-type corn picker. That way you're not totally dependent on one tractor to do the harvesting. I've helped fill many corn cribs in the past. And, been on the dumb end of a scoop shovel shelling the corn the next summer.
Good luck with your search!
SteveM C/IL
Posted: 30 Nov 2025 at 11:46am |
Around here seed corn is picked in the ear and trucked to the processing plant. Preferred moisture in mid 30's. Conveyed to big bins with forced air gas dryers. Once dry it goes to the sheller then the tower (sizing?) and then to the bagging warehouse. Oxbo is prominent brand of picker. 14 row head picking 3 panels of 4 rows.
Darwin W. Kurtz
Joined: 06 Apr 2010 Location: Westphalia, KS Points: 5646 |
Posted: 30 Nov 2025 at 12:18pm |
Grew up with a Woods Bros 16-4 picker and a flat belt driven International sheller- still have a different Woods Bros. 16-4 picker in the shed that needs a roll replaced. I have found a salvage picker close to home that has the needed part, waiting for it to get warm weather before I tackle that. I have owned several pickers that were never used by me - 1 in particular was an Allis 1 row pull type picker that was sold to a man in Nebraska (I think it was Nebraska) - he was an Allis fan and my understanding it was going in a collection. New Idea pickers are more popular it would be easier to find parts off them. Snow fence makes a good outside crib.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3651 |
Posted: 30 Nov 2025 at 1:01pm |
Macon rounds, please specify your ear corn use? Feed? Seed? Novelty(local farm&home ear corn in a bag?), Cobs??
Ear corn use could dictate machine?? Husks left on, husks removed.? Harvested moisture?? Whole cob ground feed? Shelled grain & whole cobs? Corn cob pipes? I’d vote for a pull behind New Idea ear picker because of ease of hooking-up/ unhooking it and not tying up a dedicated tractor? Think NI’s husking beds could be either aggressive or gentle?? |
dr p
Posted: 30 Nov 2025 at 2:20pm |
Macon, i thought you bought a mounted 170 ac picker a couple of years ago?
Macon Rounds
Posted: 30 Nov 2025 at 6:29pm |
I currently have a 150 picker on a D15....
Runs GREAT looks Fantastic! It was showroom clean when i bought it... Although i had to some tin work repair. Not from rust, from phisical damage not rust.... Also had lots of mechanical adjustments to do as it had never picked corn on this "RESTORED" tractor.... Anyway to this day i have NOT picked corn with it.. It is to clan and beautiful to dirty up, so i still pick by HAND.... CURRENTLY i just plant for deer and just harvest enough by hand to replant the following year... But i just purchased some cattle this summer. Who knows where that will take me... Edited by Macon Rounds - 30 Nov 2025 at 6:56pm |
Lars(wi)
Posted: 30 Nov 2025 at 6:38pm |
Over this winter, consult with a seed corn salesman( best to consult more than one), that you want a variety that works good for ‘corn picker’ not combine harvesting.
Macon Rounds
Posted: 30 Nov 2025 at 6:43pm |
I grew up with a two row mounted picker of the green variation...
So My pros and cons question was not to harvest ear or shell corn.... It was which two row picker to purchase ? A model 170 or a model 190 picker.... Or Should i buy a "new idea" two row mounted picker ??? It will be mounted on a D17 as i prefer that tractor out of all the D series tractors... Edited by Macon Rounds - 30 Nov 2025 at 6:46pm |
Macon Rounds
Posted: 30 Nov 2025 at 6:50pm |
High yield ear corn is not a concern....
I harvest my own heloom seed corn from what i plant... Although my ground fertility is improving with crop rotation, applications of lime firtilizer. I dont belive ill be over working any picker i buy... |
Macon Rounds
Posted: 30 Nov 2025 at 6:58pm |
AC720Man
Posted: 30 Nov 2025 at 7:31pm |
We picked corn to grind for winter feed for our cattle and for the 3 hogs dad raised each year for us to butcher. We used snow fence for a few years and an old chicken house before finally building a nice wire corn crib loaded from the top with our elevator. Can’t remember the manufacture but it’s still at the farm not being used. Only crop we do now is hay. If dad had corn left over then he sold it to other farmers or sold it at the Co op.
Edited by AC720Man - 30 Nov 2025 at 7:32pm |
Dennis J OPKs
Posted: 30 Nov 2025 at 8:19pm |
We ground ear corn through a hammer mill, cob & all. Cows didn't mind it & some supplements were added. Shoveled many a wagon load of ear corn into that grinder. It was flat belt powered off a WC & WD which snorted a bit under load. In later years a custom grinder did it & molasses was added, cows liked that even better.
Tom59
Joined: 27 Feb 2021 Location: Lebanon Tenness Points: 161 |
Posted: 01 Dec 2025 at 6:13am |
For five acres off corn I would just pick ear corn instead of shelling, a lot less parts and less complicated than a combine. As far as mounted corn picker versus a pull type picker if you got plenty of tractors and one you can mount a picker on and just leave it on would be great. The thing about a pull type picker you not limited to just one tractor it can go behind. But a picker would be a lot easier to keep running if you handle ear corn, which you said you can.
Macon Rounds
Posted: 01 Dec 2025 at 7:36am |
My only interest is to have a permanently mounted two row picker on a D17....
I know the basic info about the Allis pickers. However i am interested in learning about the "New Idea" pickers ??? Model numbers ? Differences ? ETC ? Any info on those pickers would be appreciated. Never seen a D series tractor with side curtains.. Edited by Macon Rounds - 01 Dec 2025 at 4:55pm |
Darwin W. Kurtz
Posted: 01 Dec 2025 at 7:37am |
The tractors in the picture with the mounted corn picker- they don't have any side curtains
Page 12> |
