Allis C oil pump gasket
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: Allis C oil pump gasket
    Posted: 23 Nov 2025 at 2:26pm
The gasket thickness provided in rebuild kit is .007” book says .001-.003” end play. Book says to lap body to reduce clearance. With out a gasket I have .003”
Thoughts on using .002 thick paper and coat with copper coat after lapping .002” off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2025 at 3:48pm
yes, you can use a piece of paper to make a gasket.. Dont use any sealer... little oil film will seal it.. The tighter the better.. If you can  get a couple thousandths off the housing, that would help.
These engines dont have but 15 psi of pressure when running... Can be less at idle, especially if you have excess clearance.. Spending some time to get the pump right is a good long term investment.
Edited by steve(ill) - 23 Nov 2025 at 3:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2025 at 3:54pm
Ok good to know. As I lapped the body I’m noticing the factory didn’t get the pump shaft perpendicular to the sealing surface.
Steiner has .004” gaskets also. I’ll hold off on any more lapping until I try a thinner gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2025 at 4:02pm
Gaskets can also take a CRUNCH when you tighten them... Best way is to make a good guess, then install and TIGHTEN.. then see if the pump turns free and possibly measure end shake.
